single v bottom with #6
Old 01-01-2007 | 05:15 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: single v bottom with #6
They dont work the best on a single engine vee
TeamSaris is offline
Old 01-01-2007 | 05:30 PM
TUFFboat's Avatar
CJ... How does the boat come on plane with the 6 compared to other, how high is the X. Does it walk sideways under acceleration?
TUFFboat is offline
Old 01-01-2007 | 05:34 PM
JCPERF's Avatar
The boat goes right on plane.The nose is straight up and then it pops level.I have the prop shaft at 11/2 inches below the back of the v.Keep in mind for every 10 inches the prop shaft is moved back go up 1 inch in prop shaft height.
JCPERF is offline
Old 01-01-2007 | 05:35 PM
TUFFboat's Avatar
With the Konrad; Does anyone know how fast they have run that gearcase profile? Is there any blowout issues at higher speeds with it? What is the diameter of the gear housing? Is it remote water intake?
Just wondering.
TUFFboat is offline
Old 01-01-2007 | 05:39 PM
TUFFboat's Avatar
Thanks JC, and does it crab at all? Or is it a small diameter prop?
TUFFboat is offline
Old 01-01-2007 | 05:43 PM
JCPERF's Avatar
It doesnt crab at all.I started with a 17 inch diameter and went down to a 16.It will probably like a little less diameter.
JCPERF is offline
Old 01-01-2007 | 05:50 PM
TUFFboat's Avatar
Thanks again JC.
If you don't mine I have another for you...
As a motor guy, what do you feel is is the most reasonable hp you would put tp a Bravo style drive? This would be a single engine Vee.
TUFFboat is offline
Old 01-01-2007 | 05:52 PM
JCPERF's Avatar
Thanks again JC.
850HP on a step bottom boat
750HP on a non step
JCPERF is offline
TeamSaris's Avatar
Driver-441
Racer
700 after that you really need to be carefull with an XR
Old 01-01-2007 | 06:04 PM
Would you feel alright with a catamaran boat 36' with 900 hp each side and Konrad's on it doing 150 mph?
p.s. I really have a problem with Mercury"s pricing on a no. 6.
Tapa11 is offline
