Pulse Drive
Old 01-06-2007 | 04:08 PM
Frequency's Avatar
Default Re: Pulse Drive
baja27 - My Envision doesn't feel loose at high speeds. The key to a successful installation is prop selection. When you trim the drive all the way down the props are pretty deep in the water. I don't have to tach up too high to get on plane. The rudders work well when on plane, and they are OK at idle speeds as long a serious course correction isn't necessary. It's no big deal to shift the transmissions in and out of neutral to turn corners. I can spin the boat in place easily. Once I get the hull bottom cleaned up and bigger props I'll be good to go.
Frequency is offline
Old 01-07-2007 | 06:53 AM
Jassman's Avatar
Originally Posted by baja27
Jassman when where docking, was it in strong current? Having the props higher up means less bite at slow speeds. Also getting up plan you really have to tach it up 4500-5000rpm. On the Pulse drive it is a rudder system so that is why I am curious as to how it handles vs a bravo style.
As to the docking with the Hustlers it was not a strong current, could not tell the difference between both the bravo and the asd-6. Also on my Arneson ASD-8 on my 4300 vs my #5 set up on the same boat the Arneson boat had a slight advantage in turning and planing, my #5's were on boxes to act like a #6, the x-dimension might have been a 1/2 high. I also have a friend with 950's/asd-6's in a 38 hustler, had problems planing at first, around 4500rpms, changed a few props, now planes around 3000 rpms, which is normal.
As to the pulse, I know of one, a Black Thunder, it lost 9mph. Also a 38 McManus Cig had them and switched back. There are two people that have them on this board and appear to be happy. I cant tell you if they gained or lost speed on their conversion but they need to anwser your Q's. With any drive there will always be a give or take depending on the application. Do your homework, go for a few rides and talk to the ACTUAL people who have the systems in place in getting the correct info. Good Luck. Jeff
Jassman is offline
Old 01-07-2007 | 07:36 AM
Thanks Jassman , I looking at a boat that has them on. Also that Hustler got to be a scary ride with such big power.
Frequency did your boat come that way or did you install it and would you go this direction again.
baja27 is offline
Old 01-07-2007 | 09:31 AM
Frequency's Avatar
I assisted a good local rigger with the installation. I bought the boat finished w/o power. The pulsedrive was the NMMA new product of the year in 2004 which shows it's potential. The number of installed units is probably much lower than Arnesons, so there is not a lot of field experience with this drive system. With the right props and a good hull bottom I think the pulsedrive has a lot to offer.
Old 01-08-2007 | 09:11 PM
Has anyone seen the 38 powerplay with this drive set up
baja27 is offline
Old 01-08-2007 | 09:21 PM
email/call/pm Steve at offshore only. He is the man when it comes to Powerplays.
Jupiter Sunsation is offline
375stinger
11
01-10-2005 05:24 AM
Zero Cavity
07-23-2003 03:33 PM
Byron
07-17-2003 05:29 PM
imongo
Cigarette
0
01-04-2003 08:43 PM
imongo
1
11-02-2002 07:34 AM
