All aluminum 1100 cubic inch V8
Nope .A buddy of mine at MSD sent it to me and I posted it on a few sites,they said its not a good motor, that its going to break the stang, the motor vibrates real bad ,cranks fail alot , bad design.I posted it on speedtalk and the owner responded there , alot of engine builders there gave some pretty good info about it,
960 lbs , the 180-degree crank is going to shake it apart.
Average operation RPM range was 1400-1600rpm
starter motors where 72volt and rated at 16HP
Each piston has 6 rings on it and has MASSIVE ring drag. Plus, they weight 4 pounds apiece
http://speedtalk.com/forum/viewtopic.php?t=5444
ck out this muther
Rolls Royce Meteor V12
http://www.youtube.com/watch?v=CJuS0jR6_E4
[url]http://www.youtube.com/watch?v=/url][CJuS0jR6_E4
I see why they say it shakes , listen to this sherman
http://www.youtube.com/watch?v=rt5uSx3eFYU
[QUOTE=Strip Poker 388;2021401]Nope .A buddy of mine at MSD sent it to me and I posted it on a few sites,they said its not a good motor, that its going to break the stang, the motor vibrates real bad ,cranks fail alot , bad design.I posted it on speedtalk and the owner responded there , alot of engine builders there gave some pretty good info about it,
It's mine. They vibrate some between 1600 and 1900, but really smooth out around 2200, and really start singing around 4000. I know guys that have twisted them to 5200, but my rev. limiter is set at 4800. The factory starter was 24 volt, but it's history anyway. I use dual Powermaster Chrysler V8 racing starters on mine, one on each side. They are working great so far. The factory pistons use 5 rings, but you don't have to use all of the grooves, and you don't have to use stock pistons. My engine uses 4 Total Seal rings on modified stock pistons. My second engine is getting custom pistons for the 32 pounds of boost that it will see on a regular basis in my pulling tractor. These old engines will make ALOT of power when built correctly. They really like turbos due to the 180 degree cranks. I built the Mustang just for fun, I don't plan on breaking any world records with it.
Several years back there was a guy named Bob Patterson out west that ran a GAA powered boat. The engine was basically stock except for the intake and carbs. It was very competitive with dual big block Chevy combos at the time.
