Trim Pump Problem
Old 02-27-2007 | 08:03 PM
Default Trim Pump Problem
Does Anyone Know If Keikeffer Pumps Differ From Drive To Tabs I Have A Drive That Wont Go Down Without A Little Coaxing I Switched Pumps With A Tab Pump And It Works Fine I Was Wondering If The Valves Are Different For Tabs And Is There Any Adjustment On Them
Baddogg is offline
Old 02-27-2007 | 08:31 PM
jhiguy377's Avatar
Dog,
Spring size/pressure on ball check valve in valve body may be different, but I've used various pumps kiek./merc./prestolite, etc interchangeably before. Check with the pros just to be sure. -Jeff
jhiguy377 is offline
Old 02-28-2007 | 06:37 AM
different psi's between the pumps but it still should work
ck your trim cylinders @ the end caps
dollerparts is offline
Old 02-28-2007 | 10:24 AM
Caps Are Free Gonna Try When The Weather Breaks
Baddogg is offline
Old 03-04-2007 | 04:43 AM
Yamaha 225's Avatar
Make sure you fill the sam oil as is on the other drive/tab. If you use a thinner oil, the tab or drive goes much faster up and down and that's a pain in the ass if you have one button on the throttle lever to run both drives simultaneousley.
Yamaha 225 is offline
Old 03-04-2007 | 05:15 AM
nocigarette's Avatar
i believe the pumps are the same if they are the old style kiek......
the only real thing that can go wrong is the solinoid
nocigarette is offline
Old 03-04-2007 | 08:02 AM
BillR's Avatar
OSO Moderator
While we're on the subject,
What weight oil goes into K-Plane reservoirs and what weight oil goes into drive trim reservoirs?
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 03-05-2007 | 01:03 PM
Biligemouth's Avatar
Also check to see if they are operating off the same battery.
Biligemouth is offline
squaz
Drives and Lower Units
5
04-06-2008 07:33 PM
boatnt
5
04-21-2007 04:28 PM
Dock Holiday
6
05-04-2006 09:42 PM
Dave1972
9
05-27-2005 09:01 PM
Allan4
3
04-14-2003 07:09 PM
