what grade should engine support bolts be ? >
Old 03-16-2007 | 11:32 AM
  #41
rv
I contacted Hillman Fasteners (large supplier for typical hardware store). I spoke with their quality engineer regarding the shear strength of their 7/16" stainless bolt. He indicated it was 6,300#'s. The bolts are ~ a grade 5 bolt. They tested from 100,000 to 150,000# (grade 5 is 120,000).
For the engine mount at the L bracket that would be a shear situation. 6,300 * 12 bolts = 75,600#'s.
Assume 5 G's of force from big wave:
1,200#'s * 5 = 6,000#'s for engine
Assume safety factor of 4:
75,600 / 4 = 18,900#'s
Seems like that should hold and still have room if assumptions are off a little.
rv is offline
Old 03-16-2007 | 11:20 PM
  #42
2112's Avatar
I would never argue a stainless bolt is a tough as Grade 8 but this logic sounds reasonable. I would also assume that if the bolts were replaced with new on each and every R&R, the chances of shearing would be even smaller. Factor in larger diameter than 7/16ths and get an even smaller chance.
Thanks RV
2112 is offline
Ken N
1
05-25-2007 06:15 AM
45sonic
Fountain
5
08-04-2005 09:15 PM
klmken
1
05-14-2005 11:17 AM
Raypanic
6
06-08-2003 07:13 PM
