Like Tree0Likes
Steel Buildings for Boat Storage... Condensation?
Old 03-19-2007, 02:44 PM
THEJOKER's Avatar
My Boats: Being a great husband and dad , boats , golf
I'm looking also - garage apartment upstairs too.
THEJOKER is offline
Old 03-19-2007, 02:46 PM
Quote:
that's awhole different bag. You're either building a "storage" building as I have, or a "house" that you store chit downstairs.
big, big difference right from the get-go.
Rippem is offline
Old 03-19-2007, 03:30 PM
ACTIVESHACK's Avatar
My Boats: 2007 37' Active Thunder SOLD
Sydwayz Have you looked into some kind of dehumidifier. Maybe something like you would need for a indoor pool.
ACTIVESHACK is offline
Old 03-19-2007, 03:43 PM
S.O.B (single O/B) now
t500hps's Avatar
Quote:
Originally Posted by Pure Energy View Post
Just for comparison, I have a 12x32x12 instant garage, with a polyethalyne cover. It gets very hot inside and there is a lot of humidity. There is mold on the inside walls and in the boat, if left for an extended periods, will get excess mold growth in the cabin.
I've got one of those too....put plastic down on the ground. Cuts the moisture issue down greatly!!!! I can see green growth on the bottom of the plastic and tell it's wet under there occasionally but the "tent" as I call it is as dry as the outside air.....but still hot as crap though.
t500hps is offline
Old 03-19-2007, 04:06 PM
Ike
Charter Member#93
Ike's Avatar
My Boats: 1989 41ft Apache Indian Outlaw
Quote:
Originally Posted by Sydwayz View Post
Carrboy,
If I have a Pole Barn built, I will be pouring a slab in the building, right up to the base boards of the building, per the barn builders specs. 'excursion' here on OSO has the IDENTICAL building that I may build; and I REALLY like how his is setup.
Brian what size pole barn is that? I am looking at putting a 40x 60 at my house.
Gellner Engineering 1025"s
Ike is offline
Old 03-19-2007, 04:40 PM
My Boats: S-29 Talbot Excavating Crew Chief
Quote:
Originally Posted by Rippem View Post
I don't know where you guys live (OK I do) but I'm 20 mins from the border up here and just last week had a 40*+ temp swing in about 12 hours. I've seen as much as 50* in 24 and this happens regularly up here in the spring and fall.
It is NEVER wet and NEVER "condensation rains" either.
My building is BONE DRY 98+% of the time. The other 2% would be a few hours of "moisture" you can just see down low on the hull of a boat while the temp equalizes that's it.
I have NEVER seen the slab damp.
has anybody who's had these issues have enough flow thru ventilation in the top of the building? Front and rear 2'x3' louver vent and a full length vented ridge and as it's a 35 yo 40'x60' building that has been moved once, there are a few spaces here and there. That slab in the pics is 22 years old.
Pics of your barn and house look really familiar...where are you?
BradH is offline
Old 03-19-2007, 04:51 PM
Forum Regulator
Trade Score: (1)
Sydwayz's Avatar
My Boats: 17' Speedliner Cat & O.P.B.
Quote:
Ike, James has a 30x74x12 with two 10Hx12W doors.
I am going to go with a 30x60x12 with identical door setup; if I go w/ the pole barn.
If I go with the SteelMaster, it will be 35x62x15. The front end wall will be inset under the roof by 2 feet to create an 'awning' and I will be siding the front of it to match the house, (which is the only thing you can view from the road).
Sydwayz is offline
Old 03-19-2007, 04:58 PM
jtmiller02
Pole barn is much more attractive..i helped stick frame a "barn" before, 100x40. It was all 2x6 with truss roof and hardi plank siding. I would go that route if possible 2nd place pole barn. The more attractive it is on the exterior the better. For a lot of buyers a big metal industrial looking building detracts from the appeal if you ever resell.
Old 03-19-2007, 05:00 PM
My Boats: Velocity 280, Mako 172
I would look at Morton Buildings too. They put mine up 2 years ago and I can't say enough good things about them. They are a little higher $$ than national barn but you get alot more quality. Haven't had any condesation problems here. PM me if you have any questions.
ThruHull is offline
Old 03-19-2007, 05:03 PM
carrboy's Avatar
My Boats: boatless
Your not insulated...that eliminates the condensation issue,and like u said,u have great ventilation.I forgot to ask if it was going to be insulated.I was going by what I have,oops
carrboy is offline
East Coast B
29
12-13-2005 08:41 AM
FunHome
09-08-2004 04:50 PM
Pure Energy
08-26-2004 09:35 PM
FormulaFan
01-06-2004 10:51 AM
