Bravo XR stuck in forward!!!
#32
Last year one of my drives locked in forward gear. It was a new XR. Shifter at the helm worked fine. Turned out a screw backed out of the shift cam and lodged between the top gear and top cap. Before I new it, the top gear shaved about 25% of the screw and put metal shavings through out the drive.
You can see the shift cam by taking the back cap off. Was simple to correct, but had to flush the drive about 10 times to get all the metal out of the drive.
It was clearly a Merc defect.
Good luck with it and hope it's simple.
This is exactly what happened with mine! Just got back from the drive shop. I need a new pinion and top gear. Craig has some spare "stuff" lying around that's pretty fresh so hopefully I don't have to buy a whole new gear set, just the pinion. My screw came to rest on top of the top gear as well, I got very lucky. If he has the parts, I can be back in business by this weekend. Too bad I'm working...
The boat was built in 03, so all warranties are probably gone unless Merc realized their screwup and is taking care of those drives that this happened to, but I doubt it.
#33
BINGO!!!
#34
Sorry to hear about additional problems. Just got in last night and started going over my messages. You are really haveing some bad luck. Hope they can get you back up and running soon. As always, if I can help give ma call or Email me.
Thanks,
Dail
Thanks,
Dail
#35
Glad its an easy fix(so-to-speak) looks I am going to have to bring my drive over and have him go thru it, I think I have some bad seals so it should be a quick fix also. I'll pressure test it tomorrow to make sure. Sorry I couldnt get up with you the other day, but things came up with work and my dad so I've been doing the I-95 tour the past couple of days between here and Daytona.
Talk to ya soon,
Trent
Talk to ya soon,
Trent
#36
Got boat back yesterday and splashed it in E. Toho for a bit. Didn't like the P5 prop, will try some fine tuning to the prop. Craig was able to pillage another outdrive for a gear since I didn't need a whole set, saved me about 1200 in the process.
PS: when you're there, ask him about the Skater that came from the same place ours did
![EEK!](/forums/images/smilies/eek.gif)
