teague engines
Old 06-05-2007 | 01:03 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The Teague 720 is naturally aspirated, and it is a BAAAAAAAD motor.
Sydwayz is offline
Old 06-05-2007 | 02:34 PM
Originally Posted by Griff
What a coincidence that there just happen to be 2 37 AT's for sale with Teague 720's
That means you can pick up the other one, Griff...
Shallow Minded is offline
Old 06-05-2007 | 03:14 PM
I had some engines built there a couple of years ago and they didn't have a dyno at that time. I don't think he has one now. He use to send them out to have that done if he needed the numbers.
Both Bob and Norm do great work, especially Norm. That 720 is a good engine. You shouldn't have anything to worry about. If you were buying them from Bob new, I would say get the warranty in writing and make sure everything is clear. Because he tries hard to get out of fixing things when you bring them back after they break. At least he's done that to me in the past.
tim mccray is offline
Old 06-05-2007 | 05:02 PM
Tbonepmp's Avatar
The Senior Charter Member #1070
What was broke?
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
Tbonepmp is offline
Old 06-05-2007 | 05:44 PM
Way!! Way!!!! over my budget.
Griff is offline
Old 06-11-2007 | 01:48 AM
I had him build two brand new engines. About 8 months later one engine blew. I never got a straight answer as to what exactly caused a cylinder to heat up and burn a piston. Before that I had to take it in a few other times for oil leaks. The valve cover bolts kept breaking. The next year the same motor blew. That time it was the crank shaft. The front of it broke off. He wouldn't warranty it the first time, so I knew he wouldn't fix it the second time either. I sold the boat right after.
Old 06-11-2007 | 02:27 AM
IŽd say either a too tight a clearance in that cylinder or running too lean probably from an intake gasket leak.
MikeyFIN is offline
Old 06-12-2007 | 01:10 AM
He doesn't stand by his warranty, but "you shouldn't have anything to worry about."
Michael1 is offline
Old 06-12-2007 | 08:05 AM
FeverMike's Avatar
Does Teague own a Dyno yet? How does he come up with the numbers to rate his engines? I have heard many stories about the lack of service after the sale with warranty issues but people keep buying them.
FeverMike is offline
Old 06-12-2007 | 11:31 AM
Lee's Avatar
Lee
Was it a Lunati crank?
Lee is offline
