Best $200 ive EVER SPENT! (20 mins in a 47' lightning, triple 525's)
#41
#44
how is this fountain price wise?
2001 Fountain 35 Lighting - $104,995
001 Fountain 35 Lighting, 35' WANT TO GO FAST 110 MPH!!!!!!!!! This is a 2001 Fountain 35 Lighting Twin Step Derebery Performance Marine 750's with Imco shorti XR Drives Hydromtive 5 blade props Very Clean Very Fast Shark Graphics 57 Hours on Hull Motors and Drives are Fresh over 100K invested in Motors and drives. FRESH WATER BOAT ONE OWNER comes with Trailer.
750's are gonna cost you a fortune in insurance and fuel. This is really a 32' (max) boat. I personally would look for stock power. 496ho, 500efi, or 525efi
#46
#47
#48
it is called a 35 fountain because it is 35' long!
i have known derebery for many years and he and his guys build a great product!
#49
Registered User
uthustler,
Fountain sticks a swim platform on their boats and an extended nose. They may look nice to some but they don't increase the effective running surface of the boat. If you sit a 35' Fountain next to a 35' Cigarette, you'll note that there's quite a bit more bottom on the Cig. This is wht the Cig will displace more water, i.e., ride better when it's sloppy. While you're there, notice that the Cig has much more freeboard (it's deeper from the keel to the deck). The Fountain is going to go faster and use less fuel, but only on light-water days. The Cig is going to plow thru the slop much better on those days that the whitecaps are kicking up. Virtually all offshore boats are built with the same basic geometry- the 24-degree v-bottom. Most are derivatives of the 35' Cigarette which is the stepson of the 32 Cary. Some have been lengthened, narrowed, etc. There have been pads, steps, notches, tapers and a zillion strake combinations tried on the bottoms.
I don't really know if any of these changes made the boats better. The definitely made them different, each in their own way. None of them have revolutionized boating, regardless of what any owner or manufacturer tells you. The one thing that has made boats better is the materials they are constructed out of. Boats have gotten progressively lighter and stronger over the years- prettyy much starting in the mid-90's. In the late 70's, raceboats were being made more and more with Kevlar, which is lighter than glass with equivalent strength. The carbon fiber came along and was being used for reinforcements in high-stress areas. Modern resins and advanced construction techniques made the boats lighter and stronger than ever. These advances have made boats "better" in many ways, but not all. While light & strong are nice attributes omn many days, that antique, 70's vintage Cig 35 is going to have a decided advantage on those really sloppy days. Like Newton says, F=MA. More simply, mass equals brute force which moves water out of your way. The Fountain 47 didn't magically move the slop out of your way on your little ride. It's a big boat with alot of mass.
As far as a "real" performance boat, there's no reason you can't find a nice boat in the $50K to $75K range. If you've got another $25 or $50K, you can get newer and nicer but not necessarily more durable. Stick with normally aspirated engines to start with. Forget a cat. Nobody is going to sell you insurance on one, let alone the other inherent issues, the least of which is that it takes a higher level of skill to operate one safely than a deep v does. You don't need a 40+ foot boat with triples to have fun- especially on a smaller lake. 34 to 38 feet is ideal. You can go in the 70 to 80 mph range with relatively reliable power and you can afford to fill the tanks. Triples can be very thirsty.
I'd start by looking in the classifieds, Boattrader.com and some of the marina's online inventores- see what catches your eye. Visit a couple that aren't too far away from you. Then start asking questions. Always remember one thing- regardless fo what boat you're looking at and how much you have to spend, they're all compromises. Make sure you narrow down your list of what compromises work best for you BEFORE you buy something. If you want creature comforts, don't buy an ex-raceboat. If you want to fly, don't buy a Formula. of course, you can have everything- it starts in the $400K range...
#50
Drive to arrive alive!!!
