tabs,,,, k planes..??
Thanks again guys... sounds like the duals should be ok if installed right , Im wondering if my buddy tryied to lower his at hi speed. Its best to go the biggest,,, the 16s? sj
Im buying a 232 islander and will installing my 550 hp 502 , it might be a 540 if the budget allows. It has no tabs at all and we do a fair bit of low speed stuff , boarding , tubing etc. Will the dual ram bennetts stand up to 75-80 mph. A buddy blew his right off , but im wondering if he had them down at 60+. thnx sj
we did a set of the EMI k-plane 17" tabs on a 20ft hammer with a 540 and the the difference was night & day. I can put you in touch with the owner if you would like to talk to someone with first hand experience.
SeaRay Sundancer
K-planes and hydro steer will be night and day on such a small boat with that kinda power. I wouldnt skimp if you are already going to the length of putting a HP motor in there. Sounds like you are keeping the boat for a while.
You can check them out at: http://www.tpmarine.com/index.asp?Pa...ROD&ProdID=855
This is what they look like.
Captain Dangerous
Do It Yourself, Boating on a Budget
3
05-23-2008 04:26 PM
