Like Tree0Likes
GPS units with fuel flow capability?
Old 08-01-2007, 09:35 PM
My Boats: '77 Hornet II
Default GPS units with fuel flow capability?
So far I've only seen the Northstar/NAVMAN and Lowrance units. From what I've read on here, the Navman fuel sensors don't get the highest reviews. Anybody have any info or experience to share with the Lowrance stuff? I wonder whose sensors they're using...
Ideally I'd like Garmin to add their aviation fuel software to their marine units, and be able to use Floscan sending units...
handfulz28 is offline
Old 08-01-2007, 09:43 PM
Fountainclimber's Avatar
I have the Navman 6600 but it works through the Smartcraft not their sensor. Seems to work OK for gph.
F
Fountainclimber is offline
Old 08-02-2007, 12:40 AM
NavMan 5500 with the flow sensors here, and it's reasonably accurate. It's not FloScan (been there) or Smartcraft accurate but pretty close for cheap in comparison.
NavMan bought by Brunswick, they buried it as they often do, then sold to Northstar.
The 5500 is now the Northstar 557 or something. Same case with grey buttons instead of blue and now that same plotter I have is C-Map "Max" compatible. Just some updated chart reading software.
Rippem is offline
Old 08-02-2007, 02:10 PM
So Rip, you're OK with the navman flow sensors? I remember reading one of your posts about them which is why I consider them sub-FloScan
I guess I'll have to do some digging to see what Lowrance is using for their sensors.
Smartcraft is nice since the ECU iterates fuel data from RPM, load and pulsewidth activity. But I've still got carbs
Old 08-02-2007, 04:54 PM
Trade Score: (1)
Ted G's Avatar
My Boats: Marlago 35 FS, 18 Neptune CC
I picked up all the Lowrancenet stuff to do my engines, fuel tank, etc, but haven't had time to install. The stuff is well made and there are alot of options once you integrate a GPS with it. The simplicity of install is pretty slick too.
www.cbpba.com
Ted G is offline
Old 08-02-2007, 05:30 PM
My Boats: Formula 292 Fastech 2002 Scorpion engines
I have recently installed Northstar 550 (same as Navman 5505) with the Navman fuel sensors, and so far I am very happy with it. I haven't calibrated the setup yet so accuracy can be improved, but it seems fine so far.
I really like the entire fuel management display screen it provides. It is truely what you need.
What are the concerns people have with the Navman fuel sensors ? Is Floscan really better ?
Phazar454Mag is offline
Old 08-02-2007, 05:58 PM
Quote:
yea I'm OK with them. I have worked with the calibration parameters available and like I said, pretty close...close enough for a 100 bucks or whatever I paid for the sensors.
BTW all the fuel capable plotters use the same sensors from the same vendor. That's what I found.
Rippem is offline
Old 08-02-2007, 06:03 PM
Quote:
than the NavMan, Standard, Lowrance ect. branded sensors?
yes.
better quality
more flow capacity (higher HP applications)
more end-install accurate as a result of more calibration combinations
I have installed and lived with both.
SmartCraft should be the most accurate for obvious reasons, but the system price to get the fuel flow info reflects that!
Rippem is offline
Old 08-03-2007, 08:58 AM
Diamond Member #001
Trade Score: (2)
C_Spray's Avatar
My Boats: 2000 Formula 382 with Innovation 600's
If your engine is NMEA 2000 compliant (only a few are so far), there are more and more units that will read the data directly from the ECM. The new Garmins will display a virtual dashboard of gauges.
My engine's aren't NMEA 2000, but I found a Brooks & Gatehouse display (4" square) that will read all the ECM data. Unfortunately, it's now out of production.
At least I didn't have to plumb and wire sensors...
C_Spray is offline
islandracer
Sonic
2
07-05-2008 01:51 PM
Rage
0
05-06-2008 12:00 PM
boatfreak
12-10-2007 04:58 PM
45sonic
Sonic
16
08-28-2007 10:14 PM
toggle throttle
07-02-2007 08:38 PM
