Like Tree0Likes
hooking two batteries together via jumpercables to charge..
Old 08-23-2007, 11:17 PM
My Boats: 24 Skater, 292 SR-1 Formula, 382 Fastech, 41 PC
Default hooking two batteries together via jumpercables to charge..
I have two batteries on my boat with no battery switches (winter project #982734892349783254).. i got to the boat today to get her ready for LOTO and both batteries were dead.. left the bilge pump switch on and the stereo and drained both. My onboard charger is toast (winter project #19) so I only have one charger. If I turn my charger up to 15 amps and hook it up to the port battery and run a set of jumper cables to the starboard battery, will both charge up overnite?
waterboy222 is offline
Old 08-23-2007, 11:25 PM
Enjoy the show
Ron P's Avatar
Sure, even a trickle will do both overnight.
Dont fry them at 15amps.
Ron P is offline
Old 08-23-2007, 11:34 PM
fountain1fan's Avatar
My Boats: 162 scout flats 90 merc
thanks ron p
fountain1fan is offline
Old 08-23-2007, 11:52 PM
My Boats: '83 Stinger260
Also if they are hooked together and you have two different rated batteries or one that took a harder hit being ran all the way down to dead, they will work against each other to try to equalize the voltage and could cycle down to nothing without having an external voltage draw. Moral of the story is disconnect them if they both recharge okay (since you don't have a switch) so they don't cycle down by themselves when not in use.
CCstinger260 is offline
Old 08-24-2007, 12:28 AM
So what setting should i put my charger on? 2, 8, or 15 with jumper cables hooked between the two..
Old 08-24-2007, 08:49 AM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
What size batteries?
Put your best foot forward!
Audiofn is offline
Old 08-24-2007, 02:24 PM
Airpacker's Avatar
My Boats: little cat...BIG MOTOR
Truth be, you shouldn't. Every battery will accept a charge ad a slightly different rate. The regulater in your charger doesn't recognise the two batteries, just an average so one could be charged too hot ( fast/current/voltage) and one to cold( slow/current/voltage). Multi bank chargers ( good ones ) read and charge each battery seperately. Charge em seperate at 15 amps and you will be fine.
Airpacker is offline
96f350psd
13
01-18-2009 08:14 AM
Strip Poker 388
10-22-2007 06:30 AM
Dregsz
06-07-2005 11:29 AM
CN24
4
06-02-2005 09:33 PM
EX20
04-08-2002 12:01 AM
