Could these be used in a boat? >
Old 09-08-2007 | 05:19 PM
Default Could these be used in a boat?
I ran across these on a website. Does anyone know what they were originally used for?
http://www.govliquidation.com/list/e3083/lna/1.html
Mackattack is offline
Old 09-08-2007 | 06:04 PM
McGary911's Avatar
Looks like one use was for ground power units used by airplanes. When your plane is boarding, and the engines are stopped, a GPU provides that semi cool air in the cabin. Easiest to notice it right before they start the engines, they unhook it, and the air stops.....
http://www.freepatentsonline.com/6424891.html
Don't know if it would do much for a hi po boat.....only 200 horse.........
McGary911 is offline
Old 09-08-2007 | 08:35 PM
GTCP series were usually used for ground air starts- many of the military jets (and some civilian airliners/corporates) utilize pneumatic starters. Bleed air off the GPU supplies the air to get the first engine started- aircraft could supply its own bleed air at that point. They also were used to drive generators or hydraulic pumps for ground power.
Adaptation for boat use would be difficult at best- you're usually talking 12,500+/- RPM at the PTO pad for the generator or pump.
A good share of the turbine engines used for boat conversions are adaptations from helicopters the Huey and Chinook to name a couple (Lycoming LTS-101, T53, T58.
jafo is offline
Old 09-08-2007 | 10:35 PM
This is an awesome site. I have not seen one question asked on the site that could not be answered by or more of the members. It is an honor to be among this group of members!
The power of this site is greater than most people could imagine. Just think of the collective information possessed by all of the OSO members.
I guess the same could be said of the collective BS!
Old 09-08-2007 | 10:40 PM
Pete B's Avatar
Charter Member#203
Veteran: Navy
They are also used as APU's, making aircraft independant of ground support equipment. On the P-3 Orion, it provided electrical, and A/C, and provided bleed air for engine starts.
Pete B is offline
Old 09-09-2007 | 01:54 AM
DirtyMoney's Avatar
Pete do you have your python on lanier?
DirtyMoney is offline
kswest
04-16-2006 11:25 AM
BK
03-11-2004 10:12 AM
Hauling Trash
06-11-2002 08:06 PM
