Steering wheel help
Old 12-08-2007 | 10:43 AM
LubeJobs42's Avatar
Default Steering wheel help
Trying to change the steering wheel on the donzi. I removed the 3/4 nut holding the wheel and hub to the helm but the wheel dosen't pull off. I see what appears to be a key way next to one side he shaft. Do I pull the wheel harder or is there something else holding it besides the 3/4" nut. The more I try to do myself the more I realize how useless I am!!!
LubeJobs42 is offline
Old 12-08-2007 | 11:04 AM
Registered User
Most likely it's on a morse taper shaft. Get a puller- either there are two or 3 threaded holes in the face of the adapter that bolts will thread into or you'll have to use a 3-jaw and reach arount to the back corner to pull it off. I've seen guys use an air chisel with a punch bit and hit the center of the shaft while someone else pulls out on the wheel but I'd be concerned with breaking something. Sears and Harbor Freight could probably fix you up today if you don't own any of these tools. Auto Zone has a free loaner program too.
Chris Sunkin is offline
Old 12-08-2007 | 11:06 AM
DTD
You could always call Trick....
DTD is offline
Old 12-08-2007 | 11:08 AM
Elite Marine's Avatar
Spray it with some WD40 or equal and use a puller.
Patience grasshopper!
Elite Marine is offline
Old 12-08-2007 | 01:43 PM
nope, closed until forever....thanks anyway
long duck dong is offline
Old 12-08-2007 | 02:27 PM
Bling Bling
Lubejob, what wheel you changing to? My Donzis finishing up next week and I'm trying to get them to change out the wheel before they mount the stock one.
blingbling is offline
Old 12-08-2007 | 02:28 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
All good ideas. Try heating it with a torch, put the nut back on (so you don't mess up the threads) and tap it with the butt end of a hammer and pull the wheel with your free hand. I had a couple of wheels that were so bad i had to cut the wheel hub off.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 12-08-2007 | 03:27 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Have removed many by loosening the nut just to where it is a hair higher than the end of the shaft. Then while 1 person is pulling firmly on the wheel with 2 hands at 180*, another person takes a hammer and smacks the nut firmly. Not so hard that you drive the nut down screwing up the threads, then not so soft you are tickling it.
US1 Fountain is offline
Old 12-08-2007 | 03:38 PM
LubeJobs42's Avatar
A torch? A Hammer?? Do you know who your talking to???? That sounds like the start of another thread!!
Old 12-08-2007 | 03:41 PM
Registered User
Gino + torch =
