Konrad/Speedmaster IIIA conversion >
Old 12-12-2007 | 02:05 PM
  #41
Is the vertical shaft splined or triangular? 1 0r 2 vertical shafts?
tizbad4 is offline
Old 12-12-2007 | 03:30 PM
  #42
Mindi
1 shaft, splined, coupler connects the lower to the upper vertical driveshaft.
Doller Offshore is offline
Old 12-12-2007 | 06:05 PM
  #43
'05 Concept SF23
Looks very straight forward. Kurt, thanks for the info. I now have 3" of spacer, so I think another inch might help getting on plane. The 5 blade Maximus prop is a Bravo prop? Smaller diamater and more pitch? I will take a good hard look @ Miami Boat Show.
f311fr1 is offline
Old 12-12-2007 | 06:50 PM
  #44
Lofty's Avatar
Very nice! Looks to be as clean and simple as the other Konrad packages. From our experience I've found the Konrad kits to include everything and have explicit instructions for retro fit. This is no exception.
Lofty is offline
Old 12-12-2007 | 06:51 PM
  #45
Biggus's Avatar
[QUOTE=f311fr1;2369745]Looks very straight forward. Kurt, thanks for the info. I now have 3" of spacer, so I think another inch might help getting on plane. The 5 blade Maximus prop is a Bravo prop? Smaller diamater and more pitch? I will take a good hard look @ Miami Boat Show.]
Yes, the Maximus is for a Bravo shaft. The Konrad unit runs a 1.25" prop shaft with an XR style hub kit.
See you in Miami!
Kurt
Biggus is offline
Old 12-12-2007 | 07:08 PM
  #46
Comanche3Six's Avatar
Originally Posted by Biggus
The Konrad/SSMIII conversion drive is 2" higher than the III
[email protected]
Kurt
How does this affect performance?
Ed
Comanche3Six is offline
Old 12-12-2007 | 07:18 PM
  #47
Biggus's Avatar
Originally Posted by Comanche3Six
Kurt
Ed
Running box stock 4 blade Powertech 28's, we gained almost 2 mph while reducing prop slip from 22% to 15%
Definetely more to be had with a labbed for the application prop.
Kurt
Biggus is offline
Old 12-12-2007 | 07:39 PM
  #48
NJSONIC's Avatar
f311fr1,
The Maximus Prop can be had in a 15 5/8 diameter.
I'm hoping Santa brings a pair this year since I didn't get them last year:-(.
I know they will work well with my Konrad conversion that Doller Offshore did on our boat two winters ago.
Hope this helps.
NJSONIC is offline
Old 12-12-2007 | 10:10 PM
  #49
'05 Concept SF23
Thanks all.
f311fr1 is offline
Old 12-13-2007 | 07:21 AM
  #50
Mindi
Default steering wing plates and finished project
This boat started out with the propshaft 5.5" below the bottom of the boat. It is now 1.7" shorter, running 26 Hydromotive p5X's 74 MPH at 5400 RPM's.
The boat has great response getting on plane, and I will post the Stats with the Maximus as soon as we test. We estimate gaining another few MPH!
Attached Thumbnails Konrad/Speedmaster IIIA conversion-oso4.jpg   Konrad/Speedmaster IIIA conversion-oso5.jpg   Konrad/Speedmaster IIIA conversion-oso6.jpg
