Conventional V-bottom hydronamics question..........
#101
montassa,
Your right with that and I guess it's relative to the size of the dimples. The porus side lifts easier because the contact patch is so much smaller than the smooth side.
I think the dynamics change when water is passing by something at 80 mph as compared to being static?
Only one way to tell make yourself a little test bed and video tape it, I don't know what will happen - maybe it works?
Debating a tech issue as you know only goes so far, you have make it and test it to get real data whether it is virtual or physical testing.
i have tried this theory, and it is good for 1 to 1.5 after the 85 mark. so in these cases it did work. i do agree about trying every theory before commenting on it directly.
#102
#103
The dimples on a golf ball move the seperation point of the air from the ball, reducing turbulence and thus drag.
This was not discovered by scientists, but, by players noticing that their well dented gutta percha golf balls traveled farther.
I don't think it will work on a boat hull bottom.
#105
a good analogy is pouring a little water on a waxed tile floor then droping a waxed tile shiny side down on top of the water . then trying to pick it up. wont be easy. flip the tile to the un finished satin side and it lifts .
same method or theory when wet sanding the bottom fore to aft.
Put your best foot forward!
#108
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
My first question is how fast is the package going to go? If you only go around 65mph, keep the motors low. Gains from reduced drag of high motor position won't show up until your around 75-80 +. If your going slower than that with a high motor setting, you will lose percentage slip and the ability to carry the bow with trim. That could make you slower.
My boat is going to be extremely lighter due to resin type and foam coring. Estimated 30% lighter.
I have 36" of set back on bracket and another 12" with notched transom.
I will be must likely be going with quad 250 efis. So I plan on running the same speed 85++if not more.......
So to pose question again ...........with notched transom and set back on 24degree deep Vee how high can I go.
Max top end is the goal.
#109
Enforcer, 36 inches and 12 inch notch. I think You'll be lucky to hit the set up on first try. Do you plan on cowlings almost touching and solid mounts? You might end up with center engines higher relative to the bottom then the outside. The outer motors will take a whopping barking in choppy water. I would think you will start with them up 9 inches or shafts even with the bottom given the are so far back. The center two maybe higher. The water will rise about 1 inch per foot of set back. I also think you'll want 3/4s of your prop in the water to carry the boat. Ultimately you may change the height a few times before your happy. If you can take pictures or measure your buddies boat it will certainly help cut down test time.
#110
Thanks for the reply. they will be on 24" centers, the beam is 9'6, I will be most likely going with pre 2002 motors-(skinny cowlings)also due to cost of four and $$$$ trying to get most bang for buck and can't see spending 70K on new engines.I was running my old Midnight with shafts even with bottom. I will do this again. I have been lookin at a lot of set ups. It looks like the Sutphen with quads uses 20"s on outers and 30"s on centers. But the beam is not as wide.
I also put my buddies Midnight in here, he is running 20's on outers and 25 centers. But his bracket is set up for 25 centers and he does not have a notched transom.
And also a Fountain.
We were both wondering how the water flow off of the v to notched transom and then to bracket will channge set up or effect the handling speed etc...
I have set my bracket up for 30" centers. Just wondering if I can get way with 25"s in center????
Thanks for the help
,Tony
