Conventional V-bottom hydronamics question.......... >
Old 12-30-2007 | 08:44 PM
  #121
CNC's Avatar
CNC
Shark skin traps air bubbles .....no stickshon (sp?) between water and bottom surface
CNC is offline
Old 12-30-2007 | 08:46 PM
  #122
A bad day boating is always better than a good day inside.
MOBILEMERCMAN is offline
Old 12-30-2007 | 08:47 PM
  #123
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
Okay now I remeber.Thanks again for the help.I'll keep ya posted
Enforcer2 is offline
Old 12-31-2007 | 12:21 PM
  #124
Knot 4 Me's Avatar
Originally Posted by marylandmark
What is a notched transom and why is it good/bad?
Post #125 shows a notched transom. Allows you to run you drives higher for less drag but still feed them plenty of water for bite.
Knot 4 Me is offline
Old 12-31-2007 | 03:19 PM
  #125
The notch is the area plugged in the mold it. It shortens the running surface, allows drives to be mounted higher and makes the bow run lighter.
Old 12-31-2007 | 03:34 PM
  #126
Semper Fi's Avatar
Depends on what you break I'd rather stay home than break a drive or engine!
Semper Fi is offline
Old 12-31-2007 | 04:14 PM
  #127
Its still better boating, besides if it was going to break waiting a day or two doesn't make it any easier.
Old 12-31-2007 | 07:14 PM
  #128
monstaaa's Avatar
Originally Posted by Audiofn
Yes but on the smooth side the tile will slide from side to side much easier. America's cup boat spend more money on speed then anyone and they no longer sand the bottoms they make them as perfectly smooth as they can.
maybe for them, but sail boats dont run over 100
monstaaa is offline
Old 12-31-2007 | 07:26 PM
  #129
Originally Posted by Enforcer2
I have heard of and tried different size pitchs on outers and centers. The problem with outeres being so high is when you turn boat they will cavitate. I went to four blades and problem was non existent.
25" centers would be a lot easier to find.
I want to keep the top of engine cowlings as close to even with each other as possible.
Here's a pict of a new Homeland Security Midnight.
http://www.offshoreonly.com/forums/s...d.php?t=176114
52 ft long.... jackplates..
Attached Thumbnails Conventional V-bottom hydronamics question..........-57a6_3.jpg
open87 is offline
Old 01-01-2008 | 07:40 PM
  #130
TUFFboat's Avatar
Enforcer2;
I'm going to ditto the info from MOBILEMERCMAN and add this... Ultimately you will check your height by doing your slip calulation. If your percentage slip is much greater than about 15%, than you know to lower that motor.
On a VEE I would try to get the props as close together as possible. I remember when people used to angle the motors on the transom to get them closer at the prop.
TUFFboat is offline
