Conventional V-bottom hydronamics question.......... >
Old 01-01-2008 | 08:50 PM
  #131
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
Originally Posted by open72
LOL I've actuall seen one continious jack plate or trips on a Deep Impact
Enforcer2 is offline
Old 01-01-2008 | 08:55 PM
  #132
Enforcer2's Avatar
This picture is really what I am interested in knowing.
This is an Apace and I know there are obvious differences.
water pickups on transom (CAN get for Outboards), surface propellers( Chopper or Cleaver Props for outboards ), HD drives and tons of Torque (thIs I can't come up with .)
But the realtionship of where the prop shaft is to the notch and the v on the bottom is really what I am after.
SEE PICT and tell me what u think.
Thanks again everyone for the help...............Tony
Attached Thumbnails Conventional V-bottom hydronamics question..........-20285_9.jpg   Conventional V-bottom hydronamics question..........-20285_9-2.jpg
Old 01-01-2008 | 09:03 PM
  #133
Are you trying to compare apples to oranges?
MOBILEMERCMAN is offline
Old 01-01-2008 | 09:35 PM
  #134
Enforcer2's Avatar
No...of course not but in relationship to the drive height and the notched transom how can I take advantage of my set up and how high should I go.
Do I run prop shafts even with bottom as before with the non notched transom or can I go as high as the above pict and actually see an increase in speed without sacrificing everything else.
It is nothing new for outboards to run much high er than your conventional stern drive boat: IE jack plates in conjuction with chopper props and low water pick ups.
Old 01-01-2008 | 09:43 PM
  #135
Tony, Do you have a rear angle picture of the stern?
As you now that hull has been a round and dialed in again and again. In short you can only raise the drives as high as you can get the props to carry the boat. The faster the boat the less you have to carry. That picture is probably of a 100 mph plus, maybe 110 mph plus boat. Different things apply as speed increases. What works at 80 is not what's best for 100 and vis versa.
Old 01-01-2008 | 09:50 PM
  #136
Enforcer2's Avatar
gotcha, 100......would be nice
I will just have to do as you said ....a lot of trial and error.
Just thinking in comparison purposes. I have looked at some lighter..much lighter by about 7000lbs and noticed that they are running their lower units pretty much like the Apache. They are also 100mph boats thought, but they are outboards-hydrostreams.
And also not in rough water.
Old 01-01-2008 | 10:00 PM
  #137
Tony, I posted on your thread I have the templates your asking about PM me with your address and I will send them to you. As far as your heights work from the homeland boat raise the centers 1 or 2 holes and see what you've got. If all is well raise them some more. Take lots of notes and calculate your slip, Have different props on hand. And the beat goes on.
Old 01-02-2008 | 09:06 AM
  #138
Enforcer2's Avatar
Thanks, really apreciate info. All PM u with address for templates
Old 01-02-2008 | 11:16 AM
  #139
They are the same and both notched. If it was not notched the transom would be one plane and it would form a V to the lowest point.
Old 01-06-2008 | 09:33 PM
  #140
Semper Fi's Avatar
That's alot of motors!!
Semper Fi is offline
