Best Upgrades 496ho???
Old 01-17-2008 | 10:00 AM
Dave M's Avatar
Veteran: Navy
Originally Posted by Griff
My suggestion..........Save your money for the next boat and get 500's or 525's in it.
What he said.
Dave M is offline
Old 01-17-2008 | 10:45 AM
tblrklakemo's Avatar
SeaRay Sundancer
Originally Posted by Knot 4 Me
Early 496 exhaust manifolds were aluminum but they are now cast iron. Not sure exactly when the switch occurred. Ray would know.
As for the upgrade, my first suggestion would be to save your money for the next boat. Second suggestion would be Raylar. If you Whipple a stock 496, sooner or later you will eat a piston.
Not sure thats true. I think all are and have been aluminum.....I have on 01' with alum and my neighbor has an 04 or 05 with alum....the elbows are SS. I would agree 100% on the save the money issue for the next boat. I just caught myslelf wanting to spend cheese on my HO...so i bought a dirtbike instead.
tblrklakemo is offline
Old 01-17-2008 | 10:48 AM
GLH's Avatar
GLH
I will quote the best line I have ever heard on OSO...
Run some boost through them biatches.
GLH is offline
Old 01-17-2008 | 11:32 AM
Michigan Mad Man
Originally Posted by GLH
I will quote the best lime I have ever heard on OSO...
I have Forged stock replacement pistons in stock for the 496's You will need them. I have them with the stock wrist pin size or I have the pin bushings and .990 pin size pistons.
TylerCrockett is offline
Old 01-17-2008 | 01:18 PM
Knot 4 Me's Avatar
I thought they were all aluminum too until I saw some threads on Merc changing over to cast iron. There was one guy that had bought a new 288 Sunsation and was mad that the paint was burning off the underside of his manifolds where they bolt up to the heads and they were rusting there already. I have an '04 boat but my 496 MAG was built 09/2003. I will double-check what my manifolds are made out of, but I'm pretty sure I have some surface rust around the gasket area where the riser bolts to the manifold.
Knot 4 Me is offline
Old 01-17-2008 | 05:12 PM
Default Raylar Hear I Come
Thanks everyone for your help but after much debate and a nice converstion with Ray from Raylar.I have decided to go with the 100 HP Raylar kit mostly for the fact that I can run it on pump gas and retain the existing exhaust manifolds to keep it quiet when the kids are aboard and around the marina.Beside the great bolt on power I like the fact that it is still reliable and user friendly and that doesnt compromise the short block components.The boat currently runs a solid 74 and with this upgrade should put me at 80+mph .Which for me in this boat is plenty for now.
live wire is offline
Old 01-17-2008 | 08:06 PM
What's the ball park cost on the Raylar's?
Ca$hed Out is offline
Old 01-17-2008 | 08:44 PM
$6400
Old 01-17-2008 | 08:47 PM
yesrej's Avatar
Originally Posted by obsessed1
live wire, there is a used raylar kit complete in the classifieds as well as used cmi headers all for the 496
where do you see this??
yesrej is offline
Old 01-17-2008 | 09:02 PM
yesrej's Avatar
nevermind i found it.
yesrej is offline
