Diesel engines in speed boat
#101
You guys are very knowledgeable.
When I started this thread I didnt know anything about marine diesels.
Now
Im ready to rebuild members diesels.
Private message me if interested.
Thanks,
38lightning
Now
Thanks,
38lightning
#102
I'll give you a it "looks great" but the specs are just for PR as it is a concept engine, doesn't apply to real word - you know I just can not give in 100% - LOL!
The diference in 3,400 or 3,000 rpm makes no difference what so ever - noone and here's my logic as to why.
gas engine 5,500 rpm's x 1.5 reduction = 3,666 prop speed
Yanmar 3,400 rpm x 1.15 red = 2,956 prop speed
Cummins 3,000 rpm x .87 OD = 3,448 prop speed
Better top end is all in the OD gearing my friend, better mid-range speed is all in the reduction
Look what I said earlier for the 38 Buzzi boat, we ran
Seatek 3,100 rpm x .83 OD = 3735 prop speed - 4 blades
Again my theory/experience if you want to run with the gas boats you need the same prop speeds.
#103
Registered User
V-8 vs I-6 Diesel
Everybody keeps arguing about how great the Duramax is. Diesels are not gas engines. Diesels run way higher compression ratios. Diesels fire by "compression ignition" another name for this is "detonation". Now in the gasoline world detonation means instant destruction of your engine but in the diesel world its business as usual. Now to handle the detonation a diesel engine has heavier and stronger pistons rods and cranks. This makes for some heavy rotating weights. These heavy weights rotating at high speeds makes for some harsh vibrations and stresses on the crank. A V-8 runs a 90 degree throw crank shaft an I-6 runs a 120 degree throw crank. This difference allows the I-6 to adsorb more stress without breaking. The smaller Cummins 5.9L engine can produce higher horsepower to displacement ratios than the Duramax V-8. If a Duramax was ever built to the same horsepower to displacement ratio as a max tuned Cummins it would tear itself apart from the stress. There is a sled puller out on the circuit that uses a modified 2 valve Cummins 5.9L that puts out 1000hp. They have $45,000 tied up in building the motor. Now for the shocker it uses a stock crank and con rods. Can you imagine building a Duramax to 1000 hp with stock rods & crank? It's called grenade engineering. The proof is in the pudding. All the high performance marine diesels are I-6s Seatek,Yanmar,Merlin,Daytona and Cummins. Take a look at the over the road trucking industry 90+% of the trucks use I-6 engines. In the real diesel world the Duramax just doesn't cut it. Horse power to displacement and horse power to weight ratio the Duramax will never be able to run with the big dogs.
#104
Registered User
The Holy Grail?
Production 42 foot boat w/ 12 foot beam. Cruises at 70 mph max speed a little over 90 mph. Diesel powered. Twin Cat C-15 ACERT engines w/ Twin Disc 2-speed gear boxes turning TRIMAX 2500 I surface drives. Is this what everyone wants?
#105
WOW - a person that's defends me!!!!
Good job - 29Firefox
Jassman - serious questions, does Nortech offer a diesel boat with anything other than Yanmar? Is there a relationship between Mastry and Nortech because I have never seen a Nortech with anything but Yanmar? Why did you build one with Yanmar over Cummins, Cat or Seatek?
#106
As to the relationship with Mastry, They have bought a few boats and serviced as well set up the boats to a certain degree. They stand behind their work and it has worked out great from my perspective. Adib Mastry is a good guy. As to why not Sea-Tek, that's self explanitory, no different than the Duramax you commented..KABOOM...
No servicing dealer either that has had a long standing good reputation. Cummins, Cat, never reserched it much at the time I was building the diesel Nortech cause of their massive weight and lower rpms, (diminishing returns higher hp to weight adv)...at that time a 2 speed trannie was just another factor or weak link to throw in there that may increase useage to be more like a gas boat, at the cost of reliability. JeffWhat 2 speed trannie, What Diesel Cummins and drive's do you like in a 43-46' boat. I would like to hear real world experiences, not theories. Thanks Jeff
#107
Another example I am familarwith is farm tractors. They are 99% Inline 6. They pull an implement thru the field 10, 12 to 15 hours a day, running at 90% thottle. The implement is lifted on the ends, the electronic trans is downshifted to slow ground speed. The turn is made and the implement dropped into the ground again and the trans upshifted and the thottle never touched. Other than the time warming up, cooling down and traveling between fields they are never coasting. A lot like a boat. Our newest Cat we expect over 11,000 hours before a rebuild, and that is with 500 hour oil changes. (The oil will be sampled at 250 hours.)
They may be heavier than the Cummins 5.9. The 8.8 liter is rated up to 320hp the 18.1 liter is rated up to 570hp. That is in field tractors.They may go higher in other aps.
#108
My perfect 43' Nortech
Use the Cummins QSC 8.3-600
Trans ZF 312 TS 1:195 or 1:00 / 0.833 2nd gear
Arneson drives
What proof it will work???? Non, other than some real world similar examples and you will have to believe that the theory works after you read this.
Super Hero 46' pleasure boat (big & heavy ex Monte Carlo), in Motorboat maginzine 1990 (month?) with me!!! Twin 600 hp 3,000 rpm Seateks and a .93 overdrive gear/single speed & Big 17.5" wheels. The magazine tests put it at 74 mph which flies in the face of everything I've said so far. The boat had great low speed planing, got on plane real well and great cruise effeciency. The Big dia wheels kept it on plane but they had no pitch.
When you ran this boat at WOT the engines didn't make any horsepower. How can I tell that? The flowscans showed we were at no where near burning what those engines burn and we were right against the governor at all times with the engines running in the cutting fuel back area past the governor.
If you prop that boat right, it can't get on plane, just can't do it.
Now, the 38 race boat which was very heavy because of construction and fuel load, (don't forget like 7X Time says those boats raced in excess of 200 miles in Europe), they carried lots of fuel and diesel weighs about 1 lb a gal more than gas!
38 race boat - under 600 hp Seateks, .83 OD gears, little props under 16" I think 15" with lots of pitch. Boat ran 92 mph but could not plane below 50-55 mph and took forever to get on plane, had to have ballast full and sometimes turn in a tight circle to get up on plane. That boat still had trouble with the rpms going past the governor!!!!
So, with a two speed you can turn a bigger dia wheel with the reduction to get up on plane and then upshift and be able to use all the available horsepower the engine has available.
I built the first pleasure 400 hp engines and put them in the field testing. Cummins Marine only 300hp versions out there when I had our 400hp running. I can if you want show you dyno sheets from 600 hp C's? Our dyno sheets were the Supeflows for short testing and developement only. We did alot of endurnace on 500 hp C's, probably about 1,100 hours continuious on a electric dyno (generator) at 80% load. They did just fine and these were all mechanical with very little modifications over a stock 300hp Marine engine.
So, I guess it's part fact and part fiction!!!!
Jeff, I enjoy our discussions, hopefully we'll meet one day?
Joe
PS, how many rpm's did your enegines turn up, my guess is you went over 3,400 which meant you weren't using all the Hp you had?
Arneson drives
Joe
#109
To answer your question if Nor Tech will build using other than Yanmar, yes they will. While the boat in the production line in front of mine is similarly rigged with Yanmar's and is going to Italy the 50 following me will have a pair of Cummins 600's (?, I'm quite sure that is what Trond told me ) and is going to Greece.
I have some very interesting plans for my new boat and will be able to share with my OSO friends shortly after launch.
I am looking forward to it.
And thanks for sharing. Keep up the good work.
Bob
#110
That is one heck of a boat, good luck!
For the record, I wasn't trying to imply anything other than some builders just like to use or will only offer certain engines.
I'd like to see those big Cummins in a smaller boat. I just don't have the ability to do myself anymore, again best of luck!
Joe Gere
Joe Gere
