Home water purification
Old 02-28-2008 | 02:26 PM
BY U BOY's Avatar
Default Home water purification
What is everyone using? I am considering the Ionics water conditioner and reverse osmosis. And since this is in the GD section the water will be used for washing the boat
http://www.aquageneral.com/products.shtml
BY U BOY is offline
Old 02-28-2008 | 06:27 PM
JLAY's Avatar
What is the reason for needing the filtering system? I don't think you have kids but filtering systems actually take out fluoride that is benificial to their health.
JLAY is offline
Old 02-28-2008 | 06:34 PM
BY U BOY's Avatar
I grew up with soft water and this city water with the chlorine is freakin killing me.
BY U BOY is offline
Old 02-28-2008 | 07:29 PM
http://residential.everpure.com/home.aspx
Have one at home, good product. Some models do not filter out fluoride.
BradH is offline
Old 02-28-2008 | 08:32 PM
Look at UV systems. If your looking to kill Ecoli and such the reverse os. won't do it even if they say they will. One way to remove some chlorine is filters that remove it. The uv lights can be expensive to maintain but work.
wipeout is offline
Old 02-28-2008 | 08:59 PM
Audiofn's Avatar
Charter Member #232
I have sulpher gas in my place in Maine that NEEDS to go!!!!
Put your best foot forward!
Audiofn is offline
Old 02-29-2008 | 07:05 AM
A lot of the time bad smelling water is the anode in the water heater. Just pull it out and put a plug in it. The heater may not last as long though.
wipeout is offline
Old 02-29-2008 | 08:16 AM
I have a 5micron in line followed by a 1 micron in line then Pure water filters at the sink. So showers and laundry water get some filtering and drinking water gets more. The 5 and 1 micron pre-filters are key, the Pure filters last much longer then. Works well. Fairly cheap, very low maintenance, changes filters now and then.
Here's where i got it all
http://www.ohiopurewaterco.com/shop/customer/home.php
Pismo10 is offline
Old 02-29-2008 | 12:20 PM
JLAY's Avatar
If you are just looking for soft water, get a water softner. Your skin actually bebefits from some chlorine in the water, and the chlorine is not what makes it hard.
JLAY is offline
Old 02-29-2008 | 12:45 PM
BY U BOY's Avatar
I know its not just the chlorine. I am looking at the water softener and a rev Osmosis for drinking.
Actually Chlorine has no benefit for your skin. It strips the skin of its protective layer and causes dry and itchy(this is what kills me) skin.Which
leads to cracking, premature aging, wrinkles and inhibiting the skin’s vital function of protecting the body.
Most Water has as much if not more chlorine in it than a swimming pool.(if it is not well water)
I know this from being a competitive swimmer for 14 years(Hurrican swim club) and doing research to find some sort of relief from the itchiness.
BY U BOY is offline
