500 efi bolt on hp?
Subscribewho has a kit with the best gains for a 500 efi 2001 without supercharging?
I would say leave it, or whipple it. No real in the middle with out pulling the motor apart, and then your at as much as a whipple would be but don't have one.
My 2 cents
WILL
My 2 cents
WILL
Quote:
Your best bet is Mark at Precision Marine in Kenner,La(504-469-7463),he can do 600 or 640 pretty reasonable and dependable.He can dyno and tune the ECU and if needed fine tune it at the lake.Originally Posted by hangem out 2dry
RobSydwayz
Forum Regulator
close
- Join DateMay 2001
- LocationWorldwide
Liked:1,592 Times in 712 Posts
Do a search on posts by "Linster" . He has done some nice upgrades to the guys local here in Richmond. I think he has built 6 or so 500EFIs into reliable 600HP/700TQ bulletproof motors with NO BLOWERS.
The Arizona Speed & Marine monoblade throttle body is a nice mod to start with. Then you need to talk about the ECU. After that, there is not much left without going inside, or supercharging.
Quote:
I guess lower but it's been a couple years since I bought mine. This will give you a bullet proof setup with a nice increase in HP. If you get ambitious, look at cams. Short of getting blown, this is probably your biggest bang for the $. Just my .02Originally Posted by dreamer
brodix heads and ecu reflash..... 10k id guess
Quote:
Each set of heads, polished and ported and built by someone who knows what they are doing...will run you about $5k all said and done. For both motors, labor, ECU flash...you are right around $10k as Ted suggested. I recently spoke with Dean Gellner about doing this to my motors...Originally Posted by Fountain38SC
Quote:
Do you know exactly what they do to get 600hp with bolt on mods ? And, what is the reliability and longevety consequences ? Originally Posted by Pantera28-650HP
Call Bill at Ateco (847)623-2737. Has a bolt on kit good for 600+ HP includes the reflashed ECU. Under $ 5,000.00.
Where is Dean when we need him???
articfriends
close
- Join DateJun 2004
- Locationfrankenmuth michigan
Liked:1,037 Times in 494 Posts
Tyler crockett is supposed to be finishing bolt on plenum tops with a built in throttle body that is re-located, He is having these casted at a foundry and will have them on the market soon. In intital testing he made 630 hp on the dyno with other mods,Smitty
