Help?I need 6 1/2 Speaker mount adapter rings >
Old 03-27-2008 | 04:32 PM
Strip Poker 388's Avatar
Rob
Question Help?I need 6 1/2 Speaker mount adapter rings
My speaker holes are to big for the 6 1/2 MB Quarts,It had the Polyplanar http://www.polyplanar.com/# which are a (odd ball size)There mounted on the panel under the seat,it has carpet on the panels.I'm thinking I need some kind of adapter ring .Here is a pick of a ring I found searching goggle, Does anybody have any suggestions and or where can I buy some adapter rings? Thanks,Rob MB is saying the cut out should be Cutout diameter: 5.16" http://www.ikesound.com/product-product_id/2795
sample pick
Attached Thumbnails Help?I need 6 1/2 Speaker mount adapter rings-11-07-2-258.jpg
Strip Poker 388 is offline
Old 03-27-2008 | 04:37 PM
Audiofn's Avatar
Charter Member #232
Get some ABS plasic and make them. You can use a router to round over the edges.
Put your best foot forward!
Audiofn is offline
Old 03-27-2008 | 04:40 PM
Mine are ABS looks good.
Attached Thumbnails Help?I need 6 1/2 Speaker mount adapter rings-boat-024.jpg
apppedigree is offline
Old 03-27-2008 | 04:41 PM
BY U BOY's Avatar
When i worked for Mobile 1 we did some pretty trick stuff with plexi. Easy to do with a router but takes some time to polish the edges and you can put some LEDs in them for some cool effects.
BY U BOY is offline
Old 03-30-2008 | 07:15 AM
Steel Outlawed's Avatar
I had prety much the same problem, except my speakers were to deep. So I made some spacers for mine out of aluminum then had them powder coated.
Steel Outlawed is offline
Old 03-30-2008 | 10:29 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I used clear plexy, rounded the corner over, polished the edges and stuck black vinyl on the back side to give it deep clear black look. I did step turn the rings ID to fit the speaker almost flush with the front of the plexy so it wouldn't look like it was just placed behind the speaker. A little more custom look to it. Plus I can also change the color of the vinyl if I choose.
US1 Fountain is offline
Old 03-30-2008 | 12:16 PM
mwdill's Avatar
that looks like a nice way to do it
mwdill is offline
Old 03-30-2008 | 10:01 PM
Rob
How do I cut the ABS with out cracking? I have a jig saw with a fine tooth blade.
jeff1000man
03-28-2007 10:19 PM
Cord
2
07-23-2004 10:30 AM
jmont34
1
07-19-2004 04:16 PM
Stormrider
12-30-2003 04:52 PM
