A/C and Honda Gen installed-38'Scarab
#41
Mike,
Do you have a picture of your boat? I remember seeing the
P-29 when it came out. I was in Destin at a Scarab dealer. I wanted that boat so bad (and I coudn't afford one then). I have never seen a P-38. I have since owned a 29, 33, and 38Scarab! What is the history behind it? Kevlar Hull?
#42
That was a great deal on the gen. I priced online and it shows $5300 just for the gen. 7k for the install,wow, that must have been a lot of labor. It sounds like it just by your description. Well ,seeing that my boat is one of a kind, it is probably worth the investment. Probably next year though. I've had it for a year and not taken it out once yet. And the baby is getting induced tommorow. Sooooooo it looks like maybe may will be the first time out.Thanks Mike
#43
You can find deals on these small gensets on ebay all the time. I have a 38 baja that came with one stock so I have not done this myself.
On a side note I have installed an ac and had the same problem with the water pump. Make sure the outlet (to ac unit) is facing north. Also my ac is designed to only engage the water pump when it is several degrees you would like to cool. In other words it will not turn on unless it is 70 and you want it to be 60. Hope that helps.
#44
Mike,
#45
Mike, Great looking boat. I don't remember what the P29 was new. It was too much for me back then. I sold my boat for $165,000. The new owner told me I can drive it any time I want. He is crazy about the boat. Yes, I do miss it but still get to drive it once in a while. I have always had a thing for Scarabs, since I grew up in Ft. Lauderdale and they were all over south Florida at the time. With all this Scarab talk back and forth the "gods" might make us go to the Scarab Forum!
#46
Very nice install !!! What are the blue lines attached to the gen ? Exhaust I assume ? Where did you route the exhaust and did you drill a thru hole in the side of the boat ? I'd also like to see pics of the AC install and plumbing as I was thinking of doing this myself. Well done and thx for the pics.
#47
On this honda generator you have installed, how are you plumbing the exhaust? Did you somehow make the exhaust water cooled?
If you're running an open exhaust in the engine room you're going to have a disaster, it was never intended to be run in closed quarters.
#48
LZH, here is a couple of pics of the A/C installed. The boat had A/C so I didnt have a lot to modify. It took about 4 hours to modify the airbox, install the unit and plumb the condensator. It has 2 -4" vent outlets inside the cabin facing up on each side of the wrap around couch.BTW did you get those drives on yet? Also there is a 29' E-ticket on page 94 of this months(May) Powerboat that has a Honda 2000 gen permanently mounted with exhaust and everything.Hmmmmm Last but not least, I would have responded earlier but I have been busy with my brand new baby girl Hailey Sue 7lbs8oz, born Thursday 10:56PM.
#49
Michael,
I'm not trying to scare you, but the gasoline fume detectors are not 100% reliable. Gasoline vapor is heavier than air, and will settle to the bottom of the bilge, right where your generator is. The Honda generator is air cooled, with plenty of hot surfaces to ignite gasoline, not to mention the non-US Coast Guard approved ignition system, intake system (backfire), and the arcing generator brushes. You pretty much have everything you need to start a fire, if not an explosion. You would be better off buying a used marine generator if you want to save cost. Then you can enjoy it, rather than worrying about it.
Michael
Michael
