Drilling & Tapping Exhaust Ports For Pyro Probes >
Old 04-19-2008 | 10:14 AM
Originally Posted by JIMKID Motorsports
the water doesnt come in untill obout 2 inches out from the flange on the headers and thats where we put them to me a lot easer just drill and weld but thats up to you and as far as good reading on the dyno we put them in the header 2 inches from the flange just my 3 cents
Thnx SKATER Bro 3 cents wher'd ya get all the xtra dough $$$$$$
Old 04-19-2008 | 01:50 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Pro1
Hotrunnin Skater Brotha, I am doin the same thing you are. I called Dart. They told me drill top down on the exhaust Port that pertrude the cylinder head. You will not have any water in that part of the casting. By the way what temp do you find optimal?
When my 500efis were stock, it would run between 1450-1550on pump gas. I was told that pump gas [93]will running higher than race gas.My Chevelle runs up to 1600 on the hwy holding it steady at 4500 to 4800.its only doing 65 at 4800rpm,on the nitrous it cools off,Now with the whipples in the Hustler it never gets above 1300, Precision Marine's dyno doing steady state pulls it would level out in the upper 1300's ,went up to 11.5 lbs of boost the temps went down, I guess the fuel map goes richer in the upper boost ranges.Rob
Strip Poker 388 is offline
Old 04-19-2008 | 02:05 PM
Rob 1300 degrees is damn good I got a buddy running 580 cubes took the intercooler off and with water coming on at 4000 & Alcohol at 8 lbs of Boost the highest i've seen is 1500 and thats 25 lbs of boost on 93 As soon as my 1" carb plates with the spray nozzles are delivered it will be test time
Old 04-20-2008 | 07:05 PM
Manley has Inconel rated up to 1500 toleration.
Pro1 is offline
JimV
108
10-05-2015 03:01 PM
michigan troll
4
04-01-2007 08:40 PM
berns29scarab
Prop Talk
9
11-14-2006 07:51 PM
cigarette39
2
03-22-2006 09:58 AM
mats
4
04-06-2003 08:24 PM
