Header drain???
Old 10-29-2015 | 10:00 AM
Originally Posted by bck
Anyone know of any electrically operated valves? I have drains on mine but it's a pain crawling around the engines to reach them.
Mine all have solenoid valves on them. Hit the switch and they drain. I'll be in the boat this weekend, I'll try to remember to get a pic with a part number.
RT930turbo is offline
Old 10-29-2015 | 10:40 AM
That would be great.
HyFive578 is offline
Old 10-29-2015 | 10:51 AM
bck's Avatar
bck
Charter Member#568
Any info or pics of your setup would be great. That's the way I'm going to go.
Straight bottoms and flat decks
bck is offline
Old 10-29-2015 | 03:25 PM
TomFTM's Avatar
Originally Posted by Tom A.
I have them on my boat and they have worked flawlessly for many years. When the engines are running there is enough pressure that the water doesn't go down the drains but as soon as you shut down, it just trickles all the trapped water right out so there is a huge reduction in the chance of reversion or leaks into the motors.
You can see them just above the waterline by the tabs.
That is the way to do it.. I started doing that the same way years ago. any stainless header system should have drains ..
TomFTM is offline
Old 11-02-2015 | 04:11 PM
Sorry guys, I didn't get pics this weekend like I hoped. I never made it to the boat. I haven't forgot about it, but I'm traveling for business the next 7 days. I will be winterizing when I get back, and will get all the info posted when I get back.
Old 11-02-2015 | 06:40 PM
bck's Avatar
bck
Charter Member#568
Ok thanks. Try to get a part # or manufacturer. Lots of solenoid valves available online, but tough to telll how well they'd fit without putting hands on them.
bck is offline
Old 11-14-2015 | 12:15 PM
Finally made it out to the boat...
One of these on each engine. [ATTACH=CONFIG]547689[/ATTACH]
Old 11-14-2015 | 12:16 PM
https://www.dudadiesel.com/choose_item.php?id=2W04008N
Old 11-14-2015 | 05:50 PM
bck's Avatar
bck
Charter Member#568
Thanks for the info
bck is offline
Old 03-02-2022 | 02:33 PM
I know its an old thread but I am in process of figuring out how I want to set up a drain system for my cmi headers. I have made some fittings with a 3/16" hole to fit where the blue drain plugs are, rather than putting a fitting through the transom, how about draining into one of the unused the sea strainer ports? When boat is under way additional water could go up through the fitting rather than loose water through the open line at transom? When the motors are off and no pressure in the strainer the headers would drain into the strainer? Thoughts????
fcs1965 is offline
