Backire through carb
Old 05-12-2008 | 10:48 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by embracethehorror
Before the last round of changes ie: metering rods plugs and prop I could only pull about 4000 rpms. With the change of these things I was able to achieve 4400 rpm but thst is when the backfire started.
Double check your work here since this is when the backfiring started.
US1 Fountain is offline
Old 05-12-2008 | 10:53 PM
You said it has been falling on it's face at wot ever since you have owned the boat. Correct? I had this happen to me right after a total rebuild. The lobe on the cam for the fuel pump wore off in less than 30min of run time after 1hour and 45min. of break in. My motor had the same symptoms you are talking about. I don't know how to tell you to check this maybe mercman can help in checking this.
B one is offline
Old 05-12-2008 | 11:28 PM
Install a in line, fuel pressure gauge at the carb.
Run it without the hatch if possible and have someone monitor it at WOT. If it starts falling, ya know what it is.
Darrell.
DMOORE is offline
Old 05-13-2008 | 04:15 AM
If the cam lobe for the fuel pump is worn wouldnt this condition exist at all rpms? Also, does anyone know what kind of pressure I should have on the fuel line at the carb?
embracethehorror is offline
Old 05-13-2008 | 12:03 PM
5-7 psi, preferably the 7psi.
Griff is offline
Old 05-13-2008 | 12:10 PM
OldSchool's Avatar
My suggestion on the first thing to do is pull the valve covers and check the pushrods and rockers. Unfortunatly, I've got alot of experience with this.
OldSchool is offline
Old 05-13-2008 | 12:54 PM
If the cam "pump" lobe is worn, it will cause a reduced movement in the fuel pump, reducing volume. At lower rpm, it may be "enough" flow for the motor. As demand increases, the pump simply cannot keep up. Just one possible cause.
I chased a backfire last year in my ski boat. Went through the same checks as you. It ended up being ONE plugged pasageway in the carb. After about a month of pulling my hair out, I was able to blow it out with compressed air....and was good to go. Total PITA.
Darrell.
DMOORE is offline
tssteph
Wanted
2
07-31-2008 08:14 AM
East Coast B
4
07-08-2005 03:57 PM
dlbCheckmate
9
10-03-2003 09:11 AM
Dean Ferry
05-15-2002 02:00 PM
