More power, use less gas on Methanol injection >
Old 07-03-2008 | 06:22 AM
  #31
Ratickle's Avatar
Does this only work on engines with boost or does it also work on NA engines with higher compression?
Ratickle is offline
Old 07-03-2008 | 07:24 AM
  #32
Call Rudy Tootie 1-302-367-4962 @ Ice and he'll answer any questions u got
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-03-2008 | 08:13 AM
  #33
WildWarrior's Avatar
We have only done extensive testing on super charged Marine engines.However in theory it does allow you to run more compression as well as more timing. So as an alternative to running race fuel it should work well in conjunction with 93 octane gasoline.
If your N/A engine is designed to run on pump gas, other than the ability to safely lean her out and add a taste of leed.
I don't believe you would see the noticeable gains that we net on blown applications.
Glen
WildWarrior is offline
Old 07-03-2008 | 08:20 AM
  #34
thunderusone's Avatar
So, what is the cost for a pair of these kits?
thunderusone is offline
Old 07-03-2008 | 12:40 PM
  #35
Coolerman's Avatar
PF Marine
Uh oh, what are you planning on doin? Also, did you get my PM?
Coolerman is offline
Old 07-03-2008 | 06:12 PM
  #36
Ratickle's Avatar
Yep, got it, thanks. For insurance purposes need to stay naturally aspirated. Been doing some research with my friends while they are working on the Toyota developement program for NASCAR. It will be down the road some, don't worry that you're BT won't be the fastest. I just want to break 100 NA.
Ratickle is offline
Old 07-04-2008 | 12:15 AM
  #37
2112's Avatar
Originally Posted by Chris Sunkin
As an extra added bonus, Rush 2112 plays when you hit their front page.
Yes, very cool
2112 is offline
RunninHotRacing163.1
02-11-2011 08:18 AM
jdhamilton00
09-22-2008 07:13 AM
SOX
05-01-2006 08:36 AM
Baddogg
7
02-01-2005 09:56 PM
candyman35
05-05-2002 12:27 AM
