700 SCi Question.
Old 07-02-2008 | 07:22 PM
Whipple Charged's Avatar
Originally Posted by Brent Medley
One of my 500 EFI's w/Whipple supercharder does the exact same thing.......swapped the IAC from the other motor and it does the same thing.........I'm stumped also
You have to adjust the idle with a scan tool then. In neutral, adjust the mechanical stop so the IAC rest between 0-20 counts (have to let it stabilize). Then, in gear, it will go between 80-140 depending on prop and gear ratio.
You must also clean the IAC filter (on Whipple kits) a minimum of once a season, otherwise it won't get enough air and will idle all over the place.
Thanks,
Dustin
Whipple Charged is offline
Old 07-02-2008 | 07:36 PM
Brent Medley's Avatar
Thanks,
Dustin
thanks, I'll try it
Brent Medley is offline
Old 07-02-2008 | 07:57 PM
omerta one's Avatar
No problems with mine but it does help to pause between shift manuevers. i.e do not go directly from forward to reverse, pull to neutral for a moment then back into gear.
omerta one is offline
Old 07-02-2008 | 08:40 PM
Chuck,
Give me a call tomorrow at the marina. I had the same issue with one of the boats we had in the shop.
Tom/Charlie
MahopacMarine is offline
Old 07-02-2008 | 08:47 PM
How long does it surge before it settles?
Back4More is offline
Old 07-02-2008 | 08:50 PM
Originally Posted by MahopacMarine
Chuck,
Give me a call tomorrow at the marina. I had the same issue with one of the boats we had in.
Tom/Charlie
Tom/Charlie,
Ok, heard you the first time! Ha ha
Hope you guys have a great 4th of july!
Dustin
Old 07-02-2008 | 08:52 PM
Tom/Charlie,
Dustin
Sorry Dustin......
It must be an East Coast thing
Enjoy the 4th man. Talk to you soon.
Tom
Old 07-02-2008 | 09:26 PM
Originally Posted by pasquesi
Throttle cable? On a fly by wire control? I don't think so.
cantoon is offline
pokerrunboats
17
07-14-2008 06:23 PM
Plaineman
Do It Yourself, Boating on a Budget
6
01-12-2008 10:46 AM
RLopez9014
12-19-2006 09:38 PM
gsmith9898
7
11-05-2006 10:29 AM
Superbabi
6
02-24-2006 01:35 PM
