Blower on top or charger on the side?
Again, not bagging on R-techs products, but I checked their website and it shows supercharger packages ,i.e. modifications to existing motors. I'm talking about mainstream engine packages don't have Centrifugal chargers- 600SCi,700SCi, 850/1075/1200SCi, Even Teague and most others seem to go with Roots style or screw blowers, knowing they are harder on drives. Is that ALL for eye candy? Knowing they are less efficient? I was going to go with a procharger setup on my 31' Scarab because of the benefit of less load down low on the drives, I sold the boat before I got around to it.
In the case of a smaller boat the roots style is a total waste. Even some bigger boats it is a waste depending on weight. For example, Cig Top Gun I'd go with roots style. Cig Gladiator I'd go Centrifugal.
I realize these guys are not marine based but they make some awesome engines with centrifugal chargers.
http://www.nelsonracingengines.com/
Generally when you say whipple that means roots.
roots style blowers make more boost at low RPM's. but they cost you in efficiency.
If you have a BIG V, or a Cat hull, roots may be better to help get the boat on plane. If you have a normal V or small V, or even a small cat, Vortech or ProCharger is better because you will get better efficiency and less cylinder pressure at low RPM's.
We made a side mount kit for awhile, but because that severly limited fitment in dual and triple applications, we stopped mfg'ing it. They worked great, excellent power, but the new stuff is better, which is mounted like a traditional supercharger, which is in the center.
Thanks,
Dustin
A centrifugal is no more efficient than a screw type. What matters is the kit, the size of the sc, rpm range, intercooler design, etc. A roots is towards the lower end of power levels, but it depends on what the mfg's are looking for. If Mercury only wants 600hp, and have a 502ci engine already, then it doesn't need to be very efficient to make 600, does it so easy. And at 4psi, it's hard to gain any advantage on blowers, because no blower is taking much power or creating much heat. Get to 10psi and above, and your talking night and day between some supercharger designs.
