Nortech Off The Trailer On I 75
#63
Registered User
2" straps are 10K/lb test each. And, you're not lifting the boat, you're holding a trailer to the bottom of it.
A good amount of downward tug with 2 straps up front and one on each rear corner bcreates alot of bunk friction that holds it from sliding as well.
#64
Ditto Chris. As long as the boat and trailer are moving together, the boat will not have the momentum to snap the straps.
#66
I had 2" yellow industrial straps on the stern and steel turn buckle on the eye hook, plus the winch cable. When 8000 (sometimes more) pounds want to go one way and the trailer goes somewhere else... it's gonna go, and did. My straps broke, turn buckle broke.. winch cable snaped and the boat went off the trailer. Beside the fact that everythng flipped.
Tie downs is a must.. but shlt does happen. Hard to overcome physics. I'm gald they'r ok, and glad and thankfull we walked away.
#68
Wrong.
#69
All I saw is my boat on the pavement, truck on the side and I was ready to cry.. I do know that my stern straps did brake.
I just checked. (I have another set.) Breaking strenght 10000 Lbs. Working load 3333 pounds. I was shocked that the stearn eye bolts didn't give first. It's also possbile the straps were draging on the pavement. Not sure..
#70
In your case I can see it happening. Things get whip'n around in opposite directions, something is gonna give. For the trailer to break and slide along, the whole thing could have stayed together if it were strapped and the weight was distributed on the trailer the way it should've been. Now one scenario I haven't seen anybody come up with yet is, did hard braking shift the boat forward on the trailer due to lack of straps and break the hitch from the excess weight and the rest is history....just a thought.
