Help...Upholstery Stain
Old 11-17-2008 | 05:05 PM
Default Help...Upholstery Stain
Brought the Cig home and found a hatch had leaked. Lifeline was wet and stained the white vinyl seat cushion. Mildew came off with mild soapy water and Magic Eraser but it won't touch the ink stain. Idears?
Thanks!!
ciaoderhead is offline
Old 11-17-2008 | 05:20 PM
Tuff-Stuff and a brush usually will get most stain out. Worth a try!
jima97 is offline
Old 11-17-2008 | 05:42 PM
johnnyo's Avatar
ever try swipes? they work pretty good.good luck.
johnnyo is offline
Old 11-17-2008 | 05:47 PM
my00b16si
start with mineral spirits and a rag. mineral spirits wil not harm the vinyl. if the stain is still there you can use lacquer thinner with a que tip on the spot only, this should do the trick. after ward clean with soap and water... what ever you do dont use aceatone it will break the finish on the vinyl.
Old 11-17-2008 | 06:20 PM
Pull the seat and place it out in the sun for a week.That tip got rid of 4 stains from black bags on my white upholstery.
skater40 is offline
Old 11-17-2008 | 10:18 PM
Clorox Clean Up and the sunlight will most likely get rid of it. I had a red shirt bleed and turn a seat pink. It took about a week of boating and a few applications, but it faded away completely.
Griff is offline
Old 11-18-2008 | 05:59 AM
marineclean's Avatar
or Shaving Cream and the Sun as Griff & Skater posted.
Follow up with Conditioner no matter what you decide to use!
marineclean is offline
Old 11-18-2008 | 07:01 AM
outriggers's Avatar
Follow up with Conditioner no matter what you decide to use![/QUOTE]
After you get it clean, Whats a good conditioner to use? Doug
outriggers is offline
Old 11-18-2008 | 07:11 AM
FYI...I have used Clorox Clean Up on my mildewed vinyl before...but I have a friend that has used diluted bleach on his interior since his boat was new (1996) and his white vinyl is YELLOW. It has cured me from using it.
Someone in another thread mentioned using denture whitening tablets disolved in water.
Good luck
JRider is offline
Old 11-18-2008 | 08:12 AM
Knot 4 Me's Avatar
Spray Nine or Fantastick and let the sun do the rest. There is no substitute for sunshine as a stain remover.
Knot 4 Me is offline
