What size box for sub
Old 12-18-2008 | 07:11 PM
Default What size box for sub
Need to make a custom box for a 12 inch sub, how big should it be? Should I port it or not? Thanks
boatguy94 is offline
Old 12-18-2008 | 07:28 PM
BDiggity's Avatar
Depends on the room you have, the music you listen to, the power you have going to sub & the sub parameters itself.
For most part a sealed box has more tight (less boomy) bass, smaller encloser, requires more power to reach same db's as a ported box.
Without knowing the sub itself, its impossible to come up w/ an accurate enclosure.
BDiggity is offline
Old 12-18-2008 | 07:53 PM
obnoxus's Avatar
Charter Member #1171
1 cubic foot is normal for a 12,,,, but you should really check with the mfg,,, as they can differ
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-18-2008 | 10:05 PM
thisistank's Avatar
Exactly true. and the CI needed is pretty specific and important to get right. Also you can't just port a sub box if the sub requires non-ported and vise/versa.
thisistank is offline
Old 12-19-2008 | 12:11 AM
if you get the brand/part number any car stereo place should be able to give you the size box it needs. for a 12 it is usually between 1 and 1.5 cubic feet. dont forget to compensate for the speaker sticking into the box. if you dont have enough room to make a big enough box, some dacron fluff can 'fool' the box into thinking it's bigger. a sealed box will be much tighter than a ported. also make sure you seal the seams and the speaker, even a very small airleak can wreck the sound.
phragle is offline
Old 12-19-2008 | 01:10 AM
thisistank's Avatar
If you're building the box yourself a trick I was taught is to mix wood glue with the left over saw dust from building the box. Mix the two and paste it to the box creases(inside). Makes a wood paste like welding.
Old 12-19-2008 | 09:07 AM
The sub is a Hifonics and the amp is a JL Audio 500. Thanks for the help.
Old 12-19-2008 | 01:14 PM
thisistank's Avatar
Call a Hifonics dealer. They'll tell you right over the phone what the CI need to be and if they can be ported or not. I would go with no port though. Like others said, tighter more solid bass with enclosed box.
OldSchool
11-06-2012 06:20 PM
SDH
04-14-2008 08:53 PM
Vyper340
10-10-2006 09:15 PM
BadDog
1
04-23-2004 10:56 AM
onesloryd
1
06-29-2002 10:40 AM
