Fuel pumps
Old 01-29-2009 | 09:44 AM
so that example would be 7 PSI ???
DareDevil is offline
Old 01-29-2009 | 09:53 AM
Originally Posted by Jb-fse
Here is a little info to help you to size a fuel pump.
horse power x.5#s = pounds of fuel per hour.
pounds per hour -: 60 = gallons per hour.
gph -: 6= gpm.
here is a example . 500hp x.5=250#s
250# -: 60= 4.16 gph
4.16gph -: 6=.69 gpm at what psi you want to run at.
if you have any questions I can help you with feel free to call we are a Sx-performance fuel pump dealer.
586-790-8880 ext 251
that's what I needed. I love the sx products--thanks ALOT!!
wet_rat is offline
Old 01-30-2009 | 10:46 AM
Default let me correct myself
fuel pump size.
typically at wide open throttle , full power, an engine requires 0.5 lbs of fuel per hp every hour.
a gallon of gas weights approximately 6.0 lbs.
exp. 500hp x .5=250lbs per hour
250lbs per hour-:- 6.0=41.66 gallons per hour
41.66gph -:- 60=.69 gpm
sorry for the confusion (bad day)
Jb-fse is offline
turbosonoma
1
10-09-2007 12:25 AM
tanner
1
08-30-2007 03:31 PM
Shah Mat
3
07-03-2004 12:42 AM
35/25
4
09-15-2003 11:42 AM
XCAV8
19
06-23-2003 06:59 AM
