i need some HELP{cobra terminator 3000} >
Old 02-08-2009 | 06:36 AM
olli is offline
Old 02-08-2009 | 06:40 AM
finally one Terminator with 2.5 EFIs:
olli is offline
Old 04-30-2010 | 09:21 AM
Originally Posted by tugboat
i need to know where i can get pics of this boat with tripple 2.5s on it and some specs. i think its call the treminator 3000 its the 30' cat center console that cobra powerboats made in the mid to late 90s.ANY HELP IS WANTED!!!
i used to work 4 cobra in th 90's we set up the race & pleasure boats w/ 2 outboards w/ short shafts you want the nose cone to ride an inch to an in & 1/2 above the 4 inch pad it runs behind off of the hull we had the engines in on brackets that stepped them off the transom about 10 inches if you want to add the center motor it would need to be a long shaft i think i am not 2 sure what the sweet spot is 4 the rigging the power head did sit a little higher w/ all three motors in line on the transom when i worked thier i did more work w/ the pleasure 30 ft w/ the blackhawk drive good luck
fastfbjrcorsa is offline
Old 04-30-2010 | 09:32 AM
northernoffshore's Avatar
http://fortmyers.craigslist.org/col/boa/1670034405.html
northernoffshore is offline
Old 04-30-2010 | 12:32 PM
Originally Posted by northernoffshore
Helluva price for a 30' cat if it's in the condition the seller says it is.
Catmando is offline
Old 04-30-2010 | 01:12 PM
lightspeed's Avatar
MD #s In Fla,,Bet Its A Scam
lightspeed is offline
STV92
11-12-2005 09:58 PM
kevinlafleur
08-30-2004 07:42 PM
