Dyno pull- Miss GEICO- project X
#51
The 53,s are amazing I cant even imagine a 55 boat.
#52
Keep in mind these engines can run at maximum takeoff power for up to 15 minutes.
A Gas Turbine engine is far superior to any piston counterpart
period. Its physics.
Here are some plots off a T53 13B. John may have some of the 703 versions.
#53
knot-right these are very impressive motor. I have never said they weren't. I was pretty sure J Arruda was incorrect with his statement that at 5700 they would make 4000 ft/lbs of torque. These motor dont drop off like piston motors. They have a very steady increasing torque curve that builds with rpms.
#57
Why would they race this boat with that kind of power? Are you sure its not for a kilo run?
Racing with this kind of power legal or not is not what this sport needs right now...
I think its great that they are trying some new things and we all know they have been great for the sport...
those are just my thoughts...
#58
John may be slightly off with his numbers However he is right on with his formula. Its not his first rodeo
Here is a the actual formula
Calculating Braking Torque:
Full-load motor torque is calculated to determine the required braking torque of a motor.
To Determine braking torque of a motor, apply this formula:
T = 5252 x HP
rpm
T = full-load motor torque (in lb-ft)
5252 = constant (33,000 divided by 3.14 x 2 = 5252)
HP = motor horsepower
rpm = speed of motor shaft
Example: What is the braking torque of a 4572 HP motor rotating at 6000 rpm?
T = 5252 x HP
rpm
T = 5252 x 4572
6000
T = 24,012,144
6000
T = 4002 lb-ft
#59
Thanks for asking.
JA
#60
Torque is equal to Hp at 5252rpm. As rpm increases, turque decreases abd hp increases just as a gas engine does.
J
