Roller Rockers/ Are they really that important >
Old 03-28-2009 | 04:24 PM
lots of good replies and info. I do have to differ on a couple of the posts or at least add my nickles worth (inflation). One mentioned RPM's 7500, keep in mind thats the crank, cams turn at half that. Cars and trucks don't use them? well I've been pulling apart the latest and greatest V6's and about half have over head cams with roller rockers. It's only time before this consept migrates into the V8's. There are a few out there all ready Toyota for one. No worries about breaking the studs then. Oh and then add in the variable valve timing features, now your moving into a down sized engine with the same HP. Throw in some direct inject and you get a few more gains in efficency and HP --- best of both worlds.
Hot Stepper is offline
Old 03-28-2009 | 10:32 PM
Default Rockers
Joe you made much sense and I couldn't agree more. I think with the rollers reducing the side loading on the valve stems, thereby reducing friction and perhaps heat is enough of a reason. That said with the higher lift cams they can certainly be put to good use. As far as any HP goes I would say there are very little gains provided the geometry is correct in both applications. I'll let you guys know this week on a 540.
I do know one thing for sure and that is I wish I was the one who invented them. Was that - Harland Sharp???
John
getrdunn is offline
Old 03-29-2009 | 02:35 AM
KAAMA's Avatar
My .02 is that I have always been told that the weakest link on a BBC is the valve train. That being considered, the "stud mounted" rocker arm system be it stamped steel or roller rockers is technology from the 1960's. The better designed rocker arm system is the "shaft mount" system such as a Jesel or T&D type. The shaft mount eliminates the need for studs, pushrod guide plates, and in some applications stud girdles. So in some cases the shaft mount system is not always that much more expensive than the stud mount system that requires those extra components.
KAAMA is offline
Old 03-29-2009 | 07:13 AM
Default Shaft mounted rocker
No debate there what so ever, shafts are better.
HabanaJoe is offline
Old 03-29-2009 | 07:42 AM
JIMKID Motorsports's Avatar
the number one reason for them is the valve train in a boat take a beating and are the weak link why do you think sterling engines changes them like socks stock or full blown race motors they are weel wodth the money my 3 cents worth
JIMKID Motorsports is offline
bwiencek
10
10-22-2013 06:16 AM
getrdunn
0
03-26-2009 08:02 PM
mpottorff
7
02-19-2008 04:07 PM
Pat McPherson
3
04-05-2007 07:56 AM
