Need Help with Carb Motor, Wont start?? >
Old 04-16-2009 | 01:17 PM
Well I didn't make any new lines. And when the engine started running, it was holding 5-7 PSI on the line. Isn't that what it's suppose to be??
KWIKSS is offline
Old 04-16-2009 | 01:26 PM
Wobble's Avatar
SORE MEMBER
that is the correct pressure, it's possible a check valve in the pump didn't close. I f your oil checks out then you may be ok, I'd still get a spare pump ready though.
I f you have a generator there is a check valve that is supposed to stop you sucking air through the gen set.
Wobble is offline
Old 04-16-2009 | 03:08 PM
I dont have a Gen.
I'll let it run awhile today and see if it runs out of fuel in the bowls..
KWIKSS is offline
Old 04-16-2009 | 04:04 PM
blue thunder's Avatar
I dont have a Gen.
Thats the idea. If you had some sort of blockage at the inlet of the carb the PSI would be fine. But if the level drops while running, you know where to look.
blue thunder is offline
