I need advise on this vessel >
Old 06-15-2009 | 01:46 AM
Default I need advise on this vessel
http://www.offshoreonly.com/classifi...o28132-en.html
I have been talking to Shogrens about this ride. I have never had and don't know chit about prochargers. We have come to a numbers agreement but I need to know about mill maintenance with the prochargers. What about the B Max drives?
wet_rat is offline
Old 06-15-2009 | 07:14 AM
I'd be a little concerned about the milky drive lube in the port bottle, and the almost zero lube in the starboard bottle. Other than that it looks like a sweet Black Thunder!
BowenCT is offline
Old 06-15-2009 | 07:57 AM
northernoffshore's Avatar
there is a thread on here about bmaxes leaking through the lower case.
northernoffshore is offline
Old 06-15-2009 | 01:53 PM
Good luck to you Eric. That boat would look good on you. Bob
bulletbob is offline
Old 06-15-2009 | 01:58 PM
Looks like a very nice boat.... but I would be concerned with the drive lube situation. Have them thoroughly checked!!!
niceguy is offline
Old 06-15-2009 | 04:30 PM
ReggieRaft's Avatar
Port side header pipe looks like it was runnig hot.
ReggieRaft is offline
Old 06-15-2009 | 05:20 PM
scarabman's Avatar
Agree on the hot header. Agree on the milky and missing drive lube and will add that the cabin sole carpet doesnt look quite right, looks discolored like maybe it was wet for a long time???????????
scarabman is offline
Old 06-15-2009 | 05:50 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Also look on the back of the transom on the port side, behind the browned header, looks like it is black or sooty...
John jr
Fenderjack is offline
Old 06-15-2009 | 08:46 PM
Here's the explaination: starboard drive is off the boat for "leaking seal" hmmmm. Milky fluid is "not milky, that's the torx (sp?) torque (sp?) drive fluid that B Max recommends. Again, hmmmm. When I asked about specifics regarding the lowers, which aren't the original B Max, told "don't know much about 'em." WTF??
wet_rat is offline
Old 06-15-2009 | 08:47 PM
I took note of that as well.
wet_rat is offline
