Blown 3 IMCO Drives, Hows the BMAX >
Old 03-28-2002 | 10:10 PM
Charter Member#350
Call Dean at the B-Max and he will tell you what to do. If the B-Max can not handle your engine then the #6 is the next step. I personaly think B-Max is the answer.
Zero Cavity is offline
Old 03-28-2002 | 10:27 PM
BLOWN 1100's Avatar
Clueless
I have a friend who has a full season on a B-Max with 1300
plus hp ,this year he is trying for 1600. Sat. is dyno day for the
monster
BLOWN 1100 is offline
Old 03-29-2002 | 07:30 AM
When you bought the drive from Imco did you tell them the HP you would be pushing through it? 900hp/tq is huge and would think Imco might steer you away. I know they do not offer warranty. It seems awfully expensive to "try" the same thing 3 times.
Pure Energy is offline
Old 03-29-2002 | 08:01 AM
jdnca1's Avatar
I know of a Carrera 257 on Lake Norman, NC with 1300 HP and 1200 ft/# that torched 9 bravo's in 2000. Went with the B-Max last season..no problems.
jdnca1 is offline
Old 03-29-2002 | 10:33 AM
Cattitude's Avatar
Default Don't forget about the size/weight
A big factor often left unsaid is boat size and weight relative to drive life. I know it's an exaggerated length Fountain but it still has considerable wt and wetted surface area, especially for that power.
I suspect the first two imcos were not the "SC Advantage" that you have now with the new beefier upper housing, pinion support and the XR gears. That drive should be a significant improvement over what you had but may not be enough.
If it's only got 5 hrs I would sell the upper and run the Bmax upper- huge difference in torque capacity, size of gears etc. Talk to Dean maybe you can swap uppers, keep your lower etc. Good luck!
Cattitude is offline
chewspit666
Fountain
28
03-23-2008 12:04 AM
txriverrat2001
0
01-15-2007 10:09 AM
txriverrat2001
7
12-12-2006 10:16 AM
johnnyboatman
1
04-09-2006 08:47 PM
Byron
01-25-2003 09:04 PM
