-   -   You're the experts - Suggestions on Diesel Go-Fast... (https://www.offshoreonly.com/forums/general-boating-discussion/213114-youre-experts-suggestions-diesel-go-fast.html)
Catmando 09-01-2009 09:54 AM
Originally Posted by Jassman (Post 2915707)
Part of what you are saying is true..but factor in weight/size to power/torque ratio and the Yanmar just works....physics... and it works reliably on numerous Nor-Tech boats...that is why they use them....call backs in the marine or any business need to be at a minimum. My 43 Nor-tech weight is more than Jays new boat and the boat hit 74.6. This is not a hi tech bottom either with multiple steps..The same set up in Adib Mastry's 39 Nor-Tech boat..(owner of Yanmar in Sarasota)...did 80 gps and I believe high 81's on radar. My deal is.. if it aint broke..leave it the heck alone.. heres a video of that Yanmar boat..click the silver boat w/red strip..39 11,000. Nor-Tech
http://www.nor-techboats.com/videos.php
Love the colors and great mold work on the deck. That setup needs at least two speed transmissions. Time to plane of 8.9sec is really poor.
Anarchy Powerboats 09-01-2009 01:56 PM
Originally Posted by HabanaJoe (Post 2912040)
Metal Bros Racing - Banks gave you a quote for $17,500 for a "tunable" Duramax that goes from 350 -550 Hp is that what you are saying?
yessir
Rik 09-01-2009 05:38 PM
Originally Posted by METAL BROS RACING (Post 2944116)
yessir
I spoke with some guys this morning in Norway that are doing the Duramax diesels, 3600 rpm 580 hp and they say they are great? Not from Gale Banks though
29Firefox 09-03-2009 05:30 AM
Btw???
Did ya ever hear back from the dude with the scarab down south of me?:drink:
goof2 09-03-2009 10:28 AM
blacklabmarine,
You might want to take a look at what this company is doing. I am assuming that this is the type of boat you would be building.
http://www.dockstavarvet.se
Their Combat Boat 90 H is used in the youtube video of German cops chasing greenpeace at a G8 summit. If this is along the lines of what you are trying to do pay particular attention to their numbers. With 1,600 hp and waterjet drives they are getting 50mph. This boat is longer than what you propose by 6 feet and probably has a little more beam.
They also have the Interceptor Craft 11 M which is about 5' shorter than what you are trying to do, but right in the weight range you mentioned (assuming they are actually using tons and not tonnes for weight measurement). With 1,000 hp and waterjets they aren't even breaking 50mph.
Working from the numbers on these boats I think you may need 2,000+ hp to get to the speeds you want, especially in a fully loaded boat.
Rik 09-03-2009 11:43 AM
Me think season is over in Japan ??
They ask for more time to test the propellers but ? Call them and give them anこんにちは
thisistank 09-03-2009 02:55 PM
2 Attachment(s)
I always liked this one!!
Duramax powered MTI...Old Tommy Bahama boat.
88Fount33 09-03-2009 03:41 PM
Originally Posted by Hot Stepper (Post 2912307)
FOund this in an email I just got. might give you some more ideas
http://machinedesign.com/article/118...ower-boat-0616
Here's the specs
Tech Specs
Length (at waterline) 100 ft
Beam 29.5 ft
Draught 4.5 ft
Displacement (half load) 95 tons
Cruising speed 60 kn
Engines Three gas turbines for 16,800 hp
Auxiliary power Two Cummins diesels for 740 hp
Range @ cruise 380 nm
Range @ 9 knots 1,500 nm
Fuel consumption @60 knots 15 gallons/nm
Fuel capacity 5,812 gallons
Fresh-water capacity 317 gallons
Water making Idromat MC-105 makes 79 gallons/hr
Generators Two 33-kW Kohler units generate 380 V @ 50 Hz
Navigation aids Autopilot, GPS, Satcom, Depth-sounder, wind instruments, radar, gyrocompass
Entertainment Hi-fi radio, three 15-in. LCD TVs, three 20-in. LCD TVs
Accommodations Six guests/Six crew
Tender 15-ft inflatable with 40-hp engine
Jet Pump Drive for the turbines is very inefficient! Surface drive would boost speed and lower fuel consumption.
Catmando 09-03-2009 05:58 PM
Hey tank wasup got any numbers on TB's new setup?
thisistank 09-03-2009 09:37 PM
Not at all bro....I got those pics 3-4 years ago when they were testing the duramax motor for marine use. Never heard what the outcome was or where the boat ended up.
I'm still curious too.
