sea pump bracket question
Old 04-02-2002 | 05:52 PM
Default sea pump bracket question
Hey guys, I am currently building a stroker motor for my Scarab and was wondering if anyone has an idea as to where I can find an extended seapump bracket to use on this thing. The problem lies with the oil pan, it has a kickout to clear the crank and it's on the side of the pump.....so it does not allow the bracket/pump to line up with mounting holes on the block(near the fuel pump) because the pump housing hits the pan when trying to do so. Any help or advise is greatly appreciated. Thanks- Scott
Scott Mc is offline
Old 04-02-2002 | 07:21 PM
Madcow's Avatar
I noticed in family perf this month Kieth Eckert had a motor displayed with some sort of aftermarket bracket. That might be a good place to start.
Madcow is offline
Old 04-02-2002 | 09:16 PM
Thanks, I'll give those guys a call. -Scott
Scott Mc is offline
Old 04-02-2002 | 10:15 PM
Audiofn's Avatar
Charter Member #232
Small or Big Block?
Audiofn is offline
Old 04-03-2002 | 08:09 AM
It's a BIG BLOCK Audiofn ....454 w/4.250 stroke .60 over (496) I had problems all last year because I kept tossing the sea pump belt. There was no way to adjust the damn thing because I was using the top bolt and kinda eeeehhh.....Jerryrigging the F&^%#ing thing. (Don't ask) Later-Scott
Scott Mc is offline
Old 04-03-2002 | 08:20 AM
Audiofn's Avatar
Charter Member #232
I assume this is a Mark 4 block. I will check out the Gen6 pump for you and see if that looks alike it will work. It is totally different from the earlier styles. It has a idler pulley to tighten the belt.
Audiofn is offline
Old 04-03-2002 | 08:24 PM
Audiofn, yep it's a Mark 4 block. It has all seperate accessory belts. I doubt if the newer style serpentine setup will come close to working. Medicine Man supplied me with a couple options though. I believe K. Eckert makes some sort of bracket to handle this problem. All it really needs is for the actual bracket arm to be about 2-3'' longer to allow use of both mounting holes/ and provide enough room for adjustment. Thanks-Scott
Scott Mc is offline
Old 04-03-2002 | 08:33 PM
Audiofn's Avatar
Charter Member #232
Mine is a Gen 6 with V belts. Check it out.
Jon
Audiofn is offline
Old 04-04-2002 | 07:54 AM
I will, thanks again! I'll let you know what the final solution ends up being. Later- Scott
Scott Mc is offline
HP500Hammer
15
01-30-2008 06:03 PM
Jeff Pierpont
0
03-20-2005 01:56 PM
H2Xmark
4
01-19-2003 07:53 PM
H2Xmark
3
01-19-2003 06:39 PM
blackhawk
06-03-2002 07:11 PM
