Bent Prop, Smashed Drive, or Trashed Engine Contest >
Old 10-02-2009 | 08:24 AM
LAriverratt's Avatar
Bad Day!! I cannot find the pictures of the block and heads. Luckily, this was nothing I owned. Oil pickup weld broke, 5000rpm, you know the rest.
Would like to see those.
LAriverratt is offline
Old 10-02-2009 | 08:28 AM
boatman22's Avatar
It has to be your boat.
It was my boat......
boatman22 is offline
Old 10-02-2009 | 09:57 AM
BY U BOY's Avatar
Have yet to pull my engine but I am pretty sure it is gonna be bad... Almost 100% sure I snapped my crank at 4K rpms a few weeks ago
BY U BOY is offline
Old 10-02-2009 | 05:26 PM
There's nothing a JBweld couldn't fix .
Looks better now
spectras only is offline
Old 10-03-2009 | 07:07 AM
Vinny P's Avatar
I hate the winter!!
This is an easy game to play..
Attached Thumbnails Bent Prop, Smashed Drive, or Trashed Engine Contest-crank-opt.jpg   Bent Prop, Smashed Drive, or Trashed Engine Contest-close-up-opt.jpg
Vinny P is offline
Old 10-03-2009 | 07:46 AM
J.B. Marshall's Avatar
JB Marshall
Spectra how did you keep her afloat with that damage? What did you hit that did not wipe out the lower? Jeeeeze
J.B. Marshall is offline
Old 10-03-2009 | 11:36 AM
Vinny, what does it take to do that? Like, elenvtybillion hp?
frickstyle is offline
Old 10-04-2009 | 01:21 PM
Oh this thread hurts...
Attached Thumbnails Bent Prop, Smashed Drive, or Trashed Engine Contest-jacksonville-poker-run-2009-013.jpg   Bent Prop, Smashed Drive, or Trashed Engine Contest-100_0790.jpg   Bent Prop, Smashed Drive, or Trashed Engine Contest-100_0791.jpg
26 REDLINE is offline
Old 10-04-2009 | 09:04 PM
usually I launch on the Upper Fraser river when I go to Georgia Strait ,and there's a lot of logboating activity there, resulting the odd logs getting loose .The river is so murky that you can't see past a few inches from the surface. Some of these logs start to sink at the heavy end and get stuck in the bottom like a fricken tree.Seen logs as big a 2' in diameter sticking out at low tide standing up straight . I was lucky , because of the trim rams and external steering rams kept the shaft from pulling out any further , even the bellows stayed intact. I hit the log with the bullet of the drive dead center [ found wood chunks in the low water pickup holes] so even the prop was untouched by the impact.
Picture showing the logs all along the shore here
Old 10-05-2009 | 10:50 AM
Nice Pair's Avatar
Thumbs down 280 Merc
Nice Pair is offline
