HD Camera In Boat Filming Question
When i going to have mine .....i will outstanding your 720p
on your big screen easy...
Your going to need to get a fixed lens. Most of the problem is from high vibrations. You can pick up a lipstick camera that records to a seperate unit like we use in our whitewater racing. Make sure you don't get a camera that has a rolling lens for example the lens is on springs or has a gyro for stablization. The camera with a stable fixed lens runs around 500.00 that includes the recording unit also. The now make them in HD and also record to memory cards.
Here is a picture of a fixed lens onboard lipstick camera. These are what we use:
http://www.helmetcamera.com/
Here is footage from that camera:
http://www.youtube.com/watch?v=GFZlfosh-K0
I read on their site that 520 is truly the highest resolution that you can get. Anyone comment on that?
The GoPro camera's are the chit.
For the money you can't beat 'em. Here's a link to some footage from one mounted on the top of a friend of mine's drag boat. I believe he was using the suction cup mount. Skip ahead to around 4 minutes or so and he gets into some full passes which are in excess of 100 mph.
You can buy the full kit for around $150 now.
http://www.youtube.com/watch?v=a8QFknaIYHo
For the money you can't beat 'em. Here's a link to some footage from one mounted on the top of a friend of mine's drag boat. I believe he was using the suction cup mount. Skip ahead to around 4 minutes or so and he gets into some full passes which are in excess of 100 mph. You can buy the full kit for around $150 now.
Amazon
Here is the link for the test video when I set it up in the MTI.
http://www.vholdr.com/node/47479
.......when it`s going to be the time ....two 1080 p are going to go to your house
