Blew a coupler - how to remove black tar = like stuff >
Old 11-01-2009 | 03:30 PM
BillR's Avatar
OSO Moderator
Default Blew a coupler - how to remove black tar = like stuff
Need some help:
I took out a coupler. When it did, the coupler blew black sticky tar like residue all over.
How do you remove it?????
I have tried Purple Power, Simple Green, acetone, citrus cleaner. . . . .
The only thing that kinda works are Swipe wipes - but only if the tar-like crap is thin. The areas where there are glops, it only smears!!!
So - anyone blown a coupler and had this black tar like crap everywhere? What did you use to clean it off??????
Help
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 11-01-2009 | 04:51 PM
bowtie's Avatar
It's not tar, it's rubber. I've used acetone and hard rubbing. If it were tar gasoline would be the answer but I haven't tried that on what you have.
bowtie is offline
Old 11-01-2009 | 05:42 PM
Bill, Try kerosene, then the other stuff you mentioned
otis311 is offline
Old 11-01-2009 | 06:45 PM
I use laquer thinner/acetone or brake cleaner(the flammable stuff-Brakekleen in the green can). Either of these will take care of it, but it will take some elbow grease. It is a nasty job that is a big giant pain in the ass. Keep working at it and it will come off. Wear gloves and a long sleeve shirt because it is a Bit@h to get off of your skin. Good luck.
Eddie
Young Performance is offline
Old 11-01-2009 | 08:17 PM
The black stuff is basically melted rubber that stuck and cooled. My first guess to remove it would have been acetone.
Griff is offline
Old 11-01-2009 | 09:13 PM
Laquer Thinner !!!!!!!
formula 382 sr-1 is offline
Old 11-01-2009 | 09:30 PM
Strip Poker 388's Avatar
Rob
gas,acetone,laquer thinner,paint thinner,petroleum based.
soak the rag let it sit on the rubber it will help melting it,I used paint thiner in the parts washer.its some nasty black buggers
Rob
Strip Poker 388 is offline
Old 11-05-2009 | 04:45 AM
Registered User
Start out with....
Start out with a razor blade and VERY CAREFULLY remove the thick stuff then move on to the chemicals
29Firefox is offline
Old 11-05-2009 | 06:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just get a bunch of yellow, blue, and red paint, and splatter some of that in there. It will then be themed to match the rest of the boat.
Sydwayz is offline
Old 11-05-2009 | 11:43 AM
Just use a torch, it will come off quickly
baja27 is offline
