Whipple 600sci upgrade documentation >
Old 12-27-2009 | 12:34 AM
  #151
CB-BLR's Avatar
Chris
Originally Posted by gnorthga
What kind of speed you think you going to get
what size prop
what is that hull rated at
I am shooting for over 100mph, and am planning on getting there.
Hydromotive P5x 30-31 pitch at 6100 rpm should get me there. I am now doing 92.5-93.3 spinning a 30 P5x at 5600 rpm. (91.5-92.1 every day)
There are several Nordic Heats in the 90-96mph range that are quite stable.(mine is one of them)
There are three Heats doing over 100 mph that I know of with the fastest doing about 112 mph. They all report hull stability at those speeds.
Chris
CB-BLR is offline
Old 12-27-2009 | 08:35 AM
  #152
Chris
someone asked the question about the bottom end to repeat his question was what about the life expectency
Dustin cam back early in one of his quotes and said they were no problems with those blocks with that being said at how many hours total will you go thru the bottom end
gnorthga is offline
Old 12-27-2009 | 11:45 PM
  #153
CB-BLR's Avatar
Chris
See post 149
Chris
CB-BLR is offline
Old 12-28-2009 | 05:42 AM
  #154
See post 149
Chris
Missed that one
Thanks!
What if we leave the motors stock
we still need to freshern up the bottom at 300?
gnorthga is offline
Old 12-28-2009 | 04:20 PM
  #155
CB-BLR's Avatar
Chris
I believe Merc recommends 400 hrs on the 700sci and 500hrs on the 600sci... I might be wrong, but that is what I remember from my owners manual.
Chris
CB-BLR is offline
Old 01-07-2010 | 03:49 PM
  #156
CB-BLR's Avatar
Chris
Dustin just e-mailed this graph showing the difference between stock..stage I, and stage II torque and horsepower.
We are still waiting for my CNC ported heads to come back so we can bolt them on and continue testing.
Chris
CB-BLR is offline
Old 02-08-2010 | 09:13 AM
  #157
We just got a exhaust header/tailpipe assembly water redo from Mercury Racing that said there was a problem with headers over heating if there is a shortage of water to the headers from a water pump failure for example and water winds up in the motor
Does the water re-route kit fix this problem as well or should a automatic header drain kit be installed
I could really use some help making a decision with this
I have a copy of the paper mercury sent us if I need to scan and post I will for anyone to see
gnorthga is offline
Old 02-08-2010 | 04:40 PM
  #158
So no one else has hear anything about this?
gnorthga is offline
Old 02-08-2010 | 07:44 PM
  #159
Chris
chris do yu have your new breathers yet?
Also do you know if the 600 water re-route is the same as the 700 re-route
gnorthga is offline
Old 02-09-2010 | 10:34 PM
  #160
CB-BLR's Avatar
Chris
I do not have my new spark arrestor, Dustin is re-designing it because of rear hatch fittment issues.
Yes, the water re-route is the same as the 700.
Chris
CB-BLR is offline
