Whipple 600sci upgrade documentation
#211
This is great info for 600 SCI owners. I have been considering the Stage 1 upgrade, all depends on what is found wrong with the starboard engine today/tomorrow. No oil pressure, went from hero to zero in the blink of an eye. Hopefully something that has to do with the oil pick up or oil pump. Engine was rebuilt by previous owner 65 hrs on it, 230 hrs over all. If the engine needs rebuilt was considering 700 cams and Whipple program. Anyone done that mod.? If engine checks ok was going to throw Stage 1 at it.
Did you see this in the swap shop?
http://www.offshoreonly.com/forums/s...ml#post4579258
Everything is for sale @ a certain $$
#212
#214
#215
What is your boat, drives, set-up, etc? I am completely stock 600 SCIs, rebuilt XRs/Sportmasters and ITS. My cautious side says not too much extra HP for the XRs
#216
I have a Howard Sportdeck 600 sci. I have switched to the Imco scx upper with the SC lower. 1.5 ratio. I have ran the boat with the stock 600... stage2... stage 4...
You are right to be concerned about the drive. I have gone through 3 drives but have 475 hours on motor. Motor was rebuild and tuned to a stage 4 whipple last year. With my old Max Machine XR it ran over 100mph. With the new SCX I have not ran it real hard yet, handling is good but it seems slower. It is also difficult to tell because testing in Lake Havasu in August is usually 110 degrees with a water temp about urine point six degrees. I have had it at 94-95 with the SCX but have not really tried for top speed. Maybe the speed will still be there... I hope.
#217
Hello from germany
i like to hear some meanings about the setup i like to do!
i have at moment an 8.2 with cmi and whipple stage 3 pcm!
i like to make now a change to an 600 sci,maybe with some whipple setup! all mount in an baja 275 ,new XR and new HP transom.
better drive with 600HP or with this setup hold for 700-750?
i drive never long time WOT as it is only a holidayboat and drive in midrange rpm!
Thanks and best regards.
michael
michael
#218
I agree. go with the stage three you will be very happy. im doing the stage 4 cam change this winter.i have a 290 hallett
