Whipple 600sci upgrade documentation
#112
Well I guess we have got all the anwsers we needed from this excellent thread
Well what is up with your Motor, what kind of power are you making
We are all waiting,
Show us those dino sheets
We are all waiting,
#113
Some of the fabrication of parts for mounting the 4.0 took longer than anticipated at the Whipple compound.
The engine is back together and on the dyno.
They are in the process of re-programming the PCM for the new cam, and we should have the numbers soon.
Chris
Chris
#114
Are you using a sportmaster 2" shorty with your scx?
#116
Standard length Imco SC lower.
I have done a LOT of testing, and my boat likes either no spacer, with a Hydromotive P5x, or a 1/2 inch spacer with a Merc Lab prop.
Below about 80 mph, the boat likes a 1 inch spacer.
With the old Whipple stage II on my 600sci, my boat did a consistant 92 mph with a best of 93.3 mph.
Chris
Chris
#117
#118
Chris
Chris
Did you change the vertical shaft or use the cupler
to connect the standard imco lower
#119
I swapped out the vertical shaft in my SC lower to a conversion shaft that IMCO makes for this purpose.
Chris
#120
Performance update:
Dustin is working dilligently on the re-programing of the Smartcraft PCM. Due to its individual cylinder ignition and fuel curve programs... this is quite a time consuming process... especially with a cam that is radically different than the original 600sci or 700sci cams.
As of last nite (9 pm), the motor is making 850 hp at 5900 rpm with 10 lbs of boost.
This is with the new cam, and the 4.0 supercharger.
Timing curves, fuel curves, and boost have not been finalized... Dustin thinks there might be more in there, and will continue to work on it.
After this round of testing, and finalization of the PCM program, Dustin will bolt the 3.3 back on and get it dialed in with the new cam.
Chris
Chris
