Mercury's Turbo Engines
Old 02-19-2010 | 09:14 PM
  #231
HotPursuit's Avatar
Originally Posted by Sean H
204K is the retail, more than one dealer quoted the 265k number though.
True depends on the market!! I know they corrected the bolts that hold the side pins on the #6 gimbals.On the 8s there not located @ 12,6,9&3 Oclock. Have broken two in the same spot right were the 1/4" bolt is located at 3 O clock. 2 yrs *****ing and was told it shouldn't be a problem and I'm running to much HP. The new pattern is 10&2 and 8&4 wow wonder why..
HotPursuit is offline
Old 02-19-2010 | 10:24 PM
  #232
Sean H's Avatar
A to Z
always nice to see some improvements huh?
not a bad package for about the same money as the 1200's.
Sean H is offline
Old 02-20-2010 | 01:41 AM
  #233
Not what I was told by Fred. 200k per package.
Cigarette has the first 6 sets.
I doubt it will cost Skip that much unless that's the factory dealer price.
Catmando is offline
Old 02-20-2010 | 01:46 AM
  #234
Originally Posted by Rexx
And don't get me started on how the baseline wankel could be improved with a few low cost aerospace materials that rotary experts have no idea about.
I hope you can get some engines started. 1300hp Wankels @500lb would be close to turbine efficiencies.
Catmando is offline
Old 02-20-2010 | 08:35 AM
  #235
Originally Posted by 44MTI
Need to sell some Merc 1200's and 6's first.
You jumped the gun Big Daddy. 1075s to 1200s to 1350s in a years time. You should have skipped the 1200s and waited for the 1350. You are not going to keep up with Gatorone with those 1200s.
Enough 4 Play is offline
Old 02-21-2010 | 12:44 PM
  #236
Believe me, if I had time and money, it already be out there. The weight savings will never beat a turbine though. One of our tubines is a tad over 500 lbs, but belts out 2500 hp continous...also cost cool mill each to (GE CT7-8a). Rotaries offer lower cost though even with top of the line internals. One day....if someone does not get there first. Dunno if you guys saw the triple rotor (20b Mazda) with a freaking huge turbo on it. It is on YouTube...900hp, single engine pushing a boat to 140 mph with a bravo xr. The bravo lives because it is screaming at 9000 rpm.
Rexx is offline
Old 02-21-2010 | 12:50 PM
  #237
JasonSmith's Avatar
That is a profoundly retarded statement.
JasonSmith is offline
Old 02-21-2010 | 02:02 PM
  #238
No torque
marylandmark is offline
Old 02-21-2010 | 05:50 PM
  #239
Precisely. 900 hp @ 9000 rpm equates to 525 ft-lbs of torque (5252/9000)x900 = 525.2 ft-lbs. Hi torque is the short term killer of drives...heat build-up is the long term killer of drives. I never understood why drives are not given a torque rating at some rpm limitation due to internal balance and heat rejection saturation.
Come on now, that was not "too" profoundly retarded. Besides, someone already has the setup running successfully!
Rexx is offline
Old 02-21-2010 | 06:16 PM
  #240
You tube video...rotary whooping on a twin bbc cig.
http://www.youtube.com/watch?v=ZdeTj7nyN-s
And here's another:
http://www.youtube.com/watch?v=bpxK2ub-qCs&NR=1
Rexx is offline
