sneak peak/ fastest 42 tiger engine >
Old 01-13-2010 | 04:44 PM
  #331
Originally Posted by Brad Zastrow
I was not running Meth at the Shootout. I was only using the 1200 setup and had full tanks of gas. We were there to have fun and planned on ruuning around LOTO more the day before to burn off gas. It did not happen so we ran the boat as is. No question the 388 Skater is a very fast hull but same power in a 39 MTI should run the same speeds. Keep in mind the Shootout is a drag race and all about setup as well. One mile is not very far when looking for a speed number. The speeds that the boats run in that distance is remarkable. Bill has his Skater dialed in for those Shootouts.
Brad, I have to disagree with you on this one, I don't believe a 39 will hang with the 388 with the same power.Gator ran 1350 hp pump gas at the shootout, mile or not 171mph is hot, It took tweaked 1550 sterlings for the CMS race boat to get to that speed. MTi's are very fast, but don't think anyone will dispute that the 388 is the fastest hull currently in this size range.the 388 prop stop boat ran mid 130's on merc 525's.
pagliahspizza is offline
Old 01-13-2010 | 04:52 PM
  #332
OL40SVX's Avatar
Originally Posted by pagliahspizza
Brad, I have to disagree with you on this one, I don't believe a 39 will hang with the 388 with the same power.Gator ran 1250 hp pump gas at the shootout, mile or not 171mph is hot, It took tweaked 1550 sterlings for the CMS race boat to get to that speed. MTi's are very fast, but don't think anyone will dispute that the 388 is the fastest hull currently in this size range.the 388 prop stop boat ran mid 130's on merc 525's.
How can you compare a 388 Skater to a 48 MTI power to speed wise??? Of course the Skater is going to be faster.....its 10ft shorter!! Surprised your not banned yet.
OL40SVX is offline
Old 01-13-2010 | 05:03 PM
  #333
drag race set up ???? well it is called a shootout for a reason & word on the water is your MTI has had meth inj set up for 3 seasons BIG Bills Pure Platinum is set up for whatever deck of cards is being dealt ...
and just for the record the red/silver skater had 100 gallons of fuel left to get to party cove & full ballast tanks
Lesson # 1 dont bring a KNIFE to a GUN f!ght
yeller gambler is offline
Old 01-13-2010 | 05:22 PM
  #334
HotPursuit's Avatar
Also keep in mind a 39 MTI is a 36 Skater with a swimplatform..My 40 is no comparison in size to a 39 MTI. Both are great hulls but I dont count anyglass that is not the running surface.. Like a fountain take away the platform and beak and you can subtract 6' from the hull size. Just saying!!
HotPursuit is offline
Old 01-13-2010 | 06:31 PM
  #335
GATORONE's Avatar
well it's 5 ft shorter in the running surface..it does not have a european diving board on the back.... open cockpit,pleasure boat..not a light weight cut down race boat....whats the canopy worth for speed....it also accelerates in poker run trim..do we need some videos
GATORONE is offline
Old 01-13-2010 | 06:58 PM
  #336
Coolerman's Avatar
PF Marine
I don't think gatorone has said how much power his motors actually make (on pump gas), and if he was actually running pump gas at the shootout....... Either way, if Gator has 1500's, that 171is still a good number in my book!.... and would make a lot more sense.
Coolerman is offline
Old 01-13-2010 | 07:02 PM
  #337
H2Xmark's Avatar
I think Dave was running alky for the shootout? if so looks like it worked out well for him
http://www.youtube.com/watch?v=2xHxSJzVshk
H2Xmark is offline
Old 01-13-2010 | 07:04 PM
  #338
GATORONE's Avatar
1350hp
GATORONE is offline
Old 01-13-2010 | 07:05 PM
  #339
Coolerman's Avatar
PF Marine
Originally Posted by GATORONE
1350hp
haha, you are a man of many words!
Old 01-13-2010 | 07:06 PM
  #340
OL40SVX's Avatar
True true, and yes I think we need some videos! Nothing like seeing a very very fast Skater in action!!
OL40SVX is offline
